Old 09-03-2017, 01:18 PM
mikebigg53 mikebigg53 is offline
Default I Can Record Just Fine, But I Can't Hear Anything on Playback
HELP!!! I have custom-built PC with an Intel-5 Quad Core Processor. Windows 10 with a Tera Byte of of memory, 16 gigs of ram, Realtek ALC892 Audio Codec, Fast Track M-Audio Interface, and U-phoria UM2 Interface. I am running Pro Tools 12.
I am able to record audio just fine, and it will play back through my monitors while I record. But when I want to listen to it after recording, I get nothing. Plus, I was just recording and mixing a few days ago, and I had no issues other than I couldn't get playback through my Behringer. Now I am not getting playback through my Fast Track either. I would usually use ASIO4ALL as my interface until I could figure out the issue, but I don't even have that option!
What could be wrong?!
Old 09-03-2017, 02:18 PM
lemmma lemmma is offline
Default Re: I Can Record Just Fine, But I Can't Hear Anything on Playback
Maybe your tracks are still record-enabled (or input-monitor-enabled) and so you're monitoring the track's input instead of playing the recorded audio? Just a guess. - lemmma
Old 09-03-2017, 05:31 PM
nope thats not the issue. my drop down tab for my behringer interface wont let me change buffer rate past 256 which is bs, its a 4k interface. my Maudio wont come up now it says "usb interface does not support the asio sampling rate " and wont let me use it. sometimes while piddling with it it will play back fine, then on second play it sounds gargled and crunchy, third play its gone.....wtf
Old 09-03-2017, 06:53 PM
Some things to check:
1-make sure the Behringer is the selected "audio engine"(Setup>Hardware)
2-make sure Windows is NOT set to use the Behringer as its default playback device.
3-make sure you are NOT in Input-Only mode(the green I button on the track or to the right of the Transport buttons). Alt-K toggles that on-off
Old 09-04-2017, 07:32 AM
check check and check. its none of those issues.got my maudio to work this morning by going in my control panel, had to reenable the device. itwas diasbled somehow...idk. anywho still no play back. anyone in STL wanna make some money fixing this for me?
Old 09-04-2017, 07:38 AM
john1192 john1192 is offline
may i ask a silly question ... do you see meters moving when you attempt playback ???
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 09-04-2017, 08:53 AM
That's a good question^^^ One mistake that is very common for newbies is to try and record a real instrument(like guitar or bass) to an INSTRUMENT track(which are actually for virtual instrument plugins)
Old 09-04-2017, 12:02 PM
lemix's Avatar
lemix lemix is offline
What does your I/O setup look like ? All tabs on default settings ?
just because the Blues are my beloved team
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Can't hear record enabled track during playback Bacek_NJ Getting Started 3 10-16-2015 11:33 AM
Cannot hear playback while in record mode. dmoffitt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-16-2012 02:33 PM
Can't hear guitar on playback only in record..... northwinds Pro Tools M-Powered (Win) 1 10-29-2007 07:39 AM
MIDI playback fine on PC - can't hear it on my Mac nancymc Pro Tools TDM Systems (Mac) 1 08-08-2005 08:49 AM
Cant hear record enabled track during playback michaiel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-19-2005 01:59 PM
