Old 07-27-2017, 05:17 AM
ijy10152 ijy10152 is offline
Default Having trouble with audio in Pro-Tools 12
Pro-Tools itself is working fine, but there's no sound coming through at all (during playback). I went through all my inputs and Outputs and they all seem to be set up correctly. I installed new drivers for my sound card and for Pro-Tools and nothing is working. Please help.
Old 07-27-2017, 08:16 AM
joachim's Avatar
joachim joachim is offline
Default Re: Having trouble with audio in Pro-Tools 12
Does Alt+K help (Auto Input Monitoring) ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 07-27-2017, 08:23 AM
It's not doing anything as far as I can tell.
Old 07-27-2017, 08:39 AM
Go to Setup>Hardware and make sure you have the correct "audio engine"
Old 07-27-2017, 01:29 PM
So this would seem a symptom of my problem. Hardware doesn't show up as an option for me.
Old 07-27-2017, 01:54 PM
You need to select something so your audio has a path to the outside world. If you're on a Mac, set it to Core Audio. If on PC, if your onboard sound card doesn't have an ASIO driver, or WASAPI(not sure of spelling) on Windows 10, try downloading ASIO4ALL, which is a free "universal" ASIO driver that might work for you. Eventually, you will want to get a real audio interface(look at Focusrite, MOTU, RME, Audient)
Old 07-28-2017, 09:18 AM
lemix's Avatar
lemix lemix is offline
""Asus x99, Intel i7 6800K, 32 gig DDR4""
Hey albee 1952,
So you have left your old faithful and trustworthy 3930K behind ?
Sorry the OT..
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 07-28-2017, 11:11 AM
To be clear, what Dave meant here was go to Setup>Playback Engine and see what options show up there in the Playback Engine pull down menu.
Old 07-28-2017, 11:37 AM
Hey albee 1952,
Sorry the OT..
Sold the older socket 1366 backup rig and turned the 3930K into the current backup rig. Still dealing with some wrinkles on the new system To Darryl; not sure if I am clear enough for the OP, so I do appreciate the assist
Old 07-28-2017, 01:34 PM
sw rec sw rec is offline
Hard to be clear with the OP when he has provided ZERO system details.
Trouble getting Pro Tools and System Audio to Play Nice weezerboy Windows 10 12-28-2016 04:23 PM
Having Trouble with M-Audio Fast Track and Pro Tools SE ncd1986 FireWire & USB Audio Interfaces (Win) 5 05-28-2013 10:05 AM
Trouble with AUDIO Setup barbara.goddy macOS 1 03-13-2013 01:32 PM
NEW PRO TOOLS USER - TROUBLE INPUTTING AUDIO JTM Digidesign Hardware & Software 0 08-23-2004 04:45 AM
Having trouble import audio sinnagod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-28-2004 08:18 PM
