Re: Locate Cursor To Start Of Region/Edit Selection
Does that not limit what's fit to window as only one of the tracks you've selected? That's the problem I'm having. Maybe I have it set up wrong all along? If I drag across a group of regions on separate tracks and go into Zoom Toggle, which I have set to fit to window, it fits to window only one of the tracks from my selection, the topmost one. I can then navigate to the ones above/below it, but it's a hassle and they aren't the same size anyway. They don't all fit to window in an intuitive way. Am I missing something? Most issues tend to be user error in the end.
Another issue in Zoom Toggle is that regions fit to window correctly vertically, but I tend to need to zoom in horizontally. They don't automatically stretch to the length of the screen. Sometimes they do and sometimes they don't. When I check what I have it set to, by clicking the vertical rule to the left of the waveform in Zoom Toggle, it always says extreme, no matter how many times I click fit to window. Clicking fit to window does not correct the horizontal zoom and it stays reading as extreme. Vertically it's exactly fit, but horizontally it's sometimes far from fitting and not always centered either. Not sure if this is a glitch or has something to do with my settings. Seems like it is intuitive for you. Hmmm...
Nap |
User error!!! As always. I had it set to remember last used and was defining it as fit to selection through the vertical rule to the left of the waveform. As soon as I set it to fit to window in the global Zoom Toggle preferences it fixed my issue. Thank you for the patience and advice.
Nap |
Right on! :)
Edit selection and playhead start | Alexander K | Pro Tools 10 | 12 | 05-30-2013 09:03 AM |
PT 7.4 HD: Link Edit- and Region List-Selection | Smico | Tips & Tricks | 2 | 10-14-2011 02:54 AM |
Move edit cursor w/region to marker? | GloryIsSilent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-25-2009 02:25 PM |
Edit Selection Follows Region List Selection->NOT! | alteregg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-14-2006 03:40 PM |
Shortcut for moving Edit Selection Start to End? | kid pro | Pro Tools TDM Systems (Mac) | 1 | 02-04-2003 11:24 AM |
