Old 02-17-2011, 02:47 PM
dl0banter dl0banter is offline
Default Hum in MBox inputs... Hum Eliminator didn't work, blnced cables didn't...
Hum X didn't work (its basically a noise gate as when I play a note, the hum comes back with the tone that is supposed to be played).
The keyboard is an Alesis QS 6.1. I get hum on either input of the MBox, it doesn't matter if I come out of the mains on the Alesis or if I go headphone jack, the hum is still there.
The hum is still there if I plug everything into the same power strip, the hum is still there when I use headphones instead of speakers etc.
I don't know what to do next... I think I've tried every permutation of combincations of things... I wonder if a $200 power conditioner will help? That's a hefty price but worth it if it actually solved this issue...
Oh... just some symptoms:
Unbalanced cables make the hum worse.... any connectors in between cable from main or headphones onthe output of the keybaord and the input on the Mbox makes it worse. A hum eliminator will double the hum noise and make the system dangerous (i get zapped when touching metal parts when this configuration is in place).
What's going on here?
D
Old 02-17-2011, 03:01 PM
anothercolour anothercolour is offline
Default Re: Hum in MBox inputs... Hum Eliminator didn't work, blnced cables didn't...
Check to see that no cable TV items are interfacing with you audio setup.
Sometimes when you use a cable box to get digital music channels, the ground differential may cause a hum.
Just a thought.
Old 02-17-2011, 03:18 PM
I tracked it down.
Why I didn't try this before I don't know. It seemed unfathomable that my keyboard was causing it, but it is. I don't know if it is power-related but I kinda doubt it. I can't believe it. No wonder I try every permutation (including getting shocked) to find this out. I need a new keyboard or at least need to get this thing fixed.
Doh.
D
Old 02-17-2011, 03:32 PM
That was exactly what I was about to type in(to try another keyboard). Glad you got it solved
Old 02-17-2011, 07:40 PM
LanceK LanceK is offline
Most of the time it is just the power supply thats messed up. If it is a wall wart, try another one. If not fixing it still may be cheaper than buying another one. Good luck!
Old 02-17-2011, 07:55 PM
Craig F Craig F is offline
try a TS 1/4" with only the Tips connected or the Shied lifted on one side
Thank you,
Craig
Mbox 2 Mini: output is okay but inputs don't work Tarktones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-21-2010 03:09 PM
wats the best trs cables for the inputs and outputs for the mbox mini? Graffic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-07-2009 05:25 PM
inputs, outputs, cables..oh my. Numi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2008 09:01 AM
Help..Mbox..Unbalanced cables or balanced cables.. DRAFT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-08-2005 07:07 PM
inputs 3-8 on 001 loose? or bad cables? jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-04-2001 10:37 AM
