unable to start my Pro Tools
Hello Guys,
I gotta big trouble! It's unable to start my PT TDM 5.0.1 (on MAC 9600). It happened suddenly, my PT was running OK and than after a few days not using it I wasn't able to start them again. While loading "WaveshellDAE 2.8.1" appears a message: UNABLE TO CREATE A DAE DECK! I've tried almost everything: checking all the cables (3x), the PCI card inside the MAC, I've also looked if I do have enough memory...... any ideas would be highly appreciated thanx Ondrej Malina, Czech Republic |
Re: unable to start my Pro Tools
Double check to make sure your extensions are all set for ProTools. You'll need to have the Digidesign System Init, Digi Stream Manager, DSP manager, and Direct I/O all turned on plus the Open Music System extension in order to run ProTools. Without the first ones listed, the card will not be initialized, therefore not seen by the software, causing the "unable to create DAE deck" error. That error basically means the cards are not being found.
it happened to me once. I needed to get a new fresh copy of DAe from the CDROM..
[img]images/icons/smile.gif[/img] [img]images/icons/tongue.gif[/img]
Alécio Costa Studio High-End e-Mastering & Music Production www.aleciocosta.com http://www.facebook.com/alecio.costa PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter. |
If the crash happens when the Waveshell launches, then the problem is likely with the Waves plug ins. Have you reinstalled them?
Pro Tools 9 unable to start up. | TechNAB76 | macOS | 9 | 08-25-2012 11:26 AM |
Unable to start new sessions in LE 6.7 | Seth Everhart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-25-2005 04:36 PM |
unable to use 002 after start up | nitogrenada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-17-2004 02:02 PM |
Unable to start PT 6.2.2 w/ Mbox and 1.25 PB | ccoes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-09-2004 01:43 PM |
unable to start my Pro Tools | Ondrej Malina | Pro Tools TDM Systems (Mac) | 7 | 10-03-2002 11:57 PM |
