Re: Joemeek or 003 preams?
U do wanna use SPDIF with that unit but however u will still get a wee bit of noise; & I must point out that the TwinQ is not a 1000 preamp; its a unit with 2 preamps, 2 comps, 2 eq & 2 DI's with SPDIF for less than a $1,000 so with that said, its a pretty cheap box but not a bad box...
Yep!
Jay< thank you.
Keybeeetsss > can you be more specific on WHY I should use spdif insted of normal cable from amp to 003? Thank you.
OS 10.8.5 , Mac Pro 2.8 GHtz , 8GB RAM, Digi003,PT10 |
U can/could use 5-8 on the rack(XLR to TRS) from the JM but to truly get all of the JM, SPDIF is the safest way to get 100% of it plus the fact its giving u 2 more channels so u could use it as inserts or som'n (although u can still do it the other way too but) jus sayin... & basically if ur not satified with the results, then either way it goes, it'll pretty much be equal so u just have to get used to the box... & too, I would grab a good tube for the K2 vs just using the stock tube; a nicse difference u will hear...
Thinking about other users who may try tha SPDIF on Joemeek Twin: forget it.
It's functional, (like the great users explain ), but you'll get extra noise. Double comparing with xlr outputs. I should mention that I use a 50$ cable, so that is not the case. Verdict: if you need extra track= maybe if you are ising it for your voice or something= forget it.
How to use the JOEMEEK compressors?? | room51 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-30-2006 02:56 PM |
Mix Questions JOEMEEK | micline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-07-2006 07:39 AM |
JOEMEEK ThreeQ or RNC?? | Ruben_B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-08-2005 08:48 PM |
OT: Where to buy joemeek MQ3? | kbahjat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-10-2003 07:53 AM |
Portable Mic Preams for DV Camera's...??? | Pako | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-17-2002 07:05 AM |
