Strike, really only 4/4 available?
Hi everyone
I was wondering if it is really true that strike can only process 4/4, no 3/4 or 6/8 at all. I could not find any way of changing the meter. Does any of you know more about this? Thanks mucho! Avoli |
You can change the meter in the Pro Tools in the tempo bar. Strike will play that time signature when the playback hits it.
Re: Strike, really only 4/4 available?
Correct, It works for me.
Set the time signature 3/4 by changing the "current meter" right above the tempo on the transport. A song that starts in 3/4 & then goes to 4/4. I do that by going to >Event >>Time Operations & selecting "Change meter". So now Pro Tools is successfuly changing from 3/4 to 4/4 where I want in the song. Strike is even performing meter changes in real time with pro tools so far.
exploration x |
It would be nice to actually have some other grooves, not only 4/4 related ones. Strike does follow time signature changes, no problem. Problem is that some of the grooves sound funny, if you shorten bar by one beat for example ( to 3/4). I recommended to Digidesign long time ago suggestions to include stuff like jazz waltz, ballroom dance waltz, and several 5/4, and 7/4 grooves in their upgrade. So far no response. I'm wondering if Strike has a design limitation that prevents it to have other rhythms than 4/4 oriented in the styles bank( 12/8 still falls into 4/4 category) ?
Chris7514 |
Perhaps an easier way... When you reach a point in a file where you wish a meter change, click on the starting point of the new meter (say in grid mode), and then select the meter tab at the left below bars/beats and timeline. A window will open allowing you to select the time sig as well as how you wish the metronome to click.. ie: I went from 4/4 with 1/4 note click to 9/16, 16th note click, and back.. simple as pie. Peace! |
filosofem |
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. | We live forever | Virtual Instruments | 55 | 09-17-2012 06:02 PM |
Strike - Songs recorded with Strike - Post Yours | JCWarrior | Virtual Instruments | 12 | 05-16-2011 12:36 PM |
Installed Strike, activated license with iLok> no Strike. | seeeker | Virtual Instruments | 3 | 10-17-2010 04:21 PM |
Upgraded to PTIEP from Strike, do I need to uninstall Strike 1.0.2 first? | cmedina | Virtual Instruments | 0 | 04-20-2010 09:37 AM |
DAE error #7400 PC (STRIKE only)????? STRIKE WONT LOAD!! | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2008 08:19 PM |
