Pro Tools LE 6.9.2 update failed
use tiger (os X) 10.4.2 and ugradet from 6.4 to 6.9 per official CD package. Now the update to 6.9.2 fails, says: Can´t find 6.7 - you need version 6.7......what the f!?*...recommended is 6.7 AND 6.9.....you can read it everywhre...what about new hardware releases wich are ONLY delivered with 6.9. How do they update? Help welcome ;-)
Re: Pro Tools LE 6.9.2 update failed
When you say you updated from 6.4 to 6.9 per 'official cd package' - what are you referring to? Is this a Pro Tools 6.9 upgrade you purchased on the Digistore or from a dealer?
If your 6.9 installer does not say 'update' on it, then you should uninstall both 6.9 and 6.4, then reinstall 6.9 from that cd. You should then be able to run the 6.9.2 updater. |
@ DigiTechSupt
Thanx for the fast answer.... let me explain it to you: well, I got an 6.9 upgrading kit from my dealer as I told him about my new tiger 10.4.2 system. I installed the 6.9 over the existing 6.4 and it works fine. only the 6.9.2 downloadable update doesn´t work. so - obviously I am owner of of a normal 6.9 upgrade. and it should be able to be updated to 6.9.x whatever - . maybe the row of inastallation causes the problem. I first installed 6.9 and than installed tiger? anyway - how can I fix this - cause I definetly need 6.9.2 |
Now that you have upgraded to Tiger, reinstall 6.9 from the CD, then the update to 6.9.2. The Tiger OS install probably replaced some necessary files.
The 6.9 dealer inventory update kit you have should include a full installer CD for PTLE 6.9 that does not require any previous version of Pro Tools. The PTLE 6.9.2 web updater requires either PTLE 6.7 or 6.9, even if the error message mistakenly says "6.7 not found".
Administrator Avid Pro Audio Community |
ANSWER FROM striegl
i fixed the bug - thanx a lot. i deleted every digidesign folder except my plugIns and installed everything new. afterwards the 6.9.2 update was successfull! so the way is.....tiger first....than protools....tiger probably "destroyed" my LE. thnx from germany |
You're welcome, glad you got it working. I'm actually flying into Frankfurt on Monday morning. If you could get it to stop raining by then, I would appreciate it.
Update to 10.3.2 failed, can't reinstall 10.0 | rickluque12 | Pro Tools 10 | 5 | 11-01-2012 10:33 AM |
FWx firmware update failed! | sersol | VENUE Live Sound Systems | 4 | 09-14-2012 11:49 AM |
Mbox 2 failed firmware update!! Help! | circuit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 05-15-2012 02:01 PM |
Update to 9.0.1 Failed | 0just_ice | Pro Tools 9 | 9 | 01-24-2011 10:14 PM |
003R Firmware Update Failed...7.3 to 7.4 | Kourquie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-22-2009 01:22 PM |
