Old 07-22-2013, 02:05 PM
esetheridge esetheridge is offline
Default Help! Latency problems on Pro Tools 10 with Tascam US-2000
I am needing help getting my Tascam US-2000 to work with Pro Tools 10. I am having trouble with latency issues. I have tried setting the latency to allow the highest latency on the Tascam control panel, though Pro Tools will not even open when this setting is enacted, instead giving the message "The selected ASIO device could not be initialized. Please choose another audio device." When the latency is set on just "High latency", Pro Tools will open. However, after about five minutes, I will experience delays and then clicks, pops, and noise. I have gone to the playback settings in Pro Tools to try and fix this but I do not know what to set them on in order to solve the problem. I have tried setting the delay compensation to short, long, and maximum. And the buffer rate is locked in at 256 samples. Does anyone know of the right combination of settings I can use so that I can use my system?
I also should note that I know for a fact that the system CAN work. I have been using this setup for a little over a year now. I have only now begun to experience some difficulty after having to restore my computer to factory settings and reinstall Pro Tools 10 as well as Pro Tools 11. (Pro Tools 11 won't even come up, though I'm afraid that is a technical issue I will worry about at another time. My first concern is getting my system to function before tackling the next big problem.)
Any and all help is appreciated!!!!!
Tascam US-2000 works with Pro Tools 10? marcnyc Pro Tools 10 1 05-25-2012 09:04 AM
Playback Latency off by 2000 samples willl3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-06-2009 09:17 AM
setting up a tascam cdrw 2000? jackp Pro Tools TDM Systems (Win) 1 05-13-2009 07:17 PM
output to my tascam cdrw 2000 ? jackp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-09-2006 10:52 AM
midi through pro tools 6.4 and mpc 2000 PROBLEMS.. mr. district 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-23-2005 09:52 PM
