PT10 crashes when attempting to assign m-audio midi controller
Hello I know this was brought up in another post but I believe the title of the thread wasnt descriptive enough so i thought id offer a bit more insight...
mac pro 10.6.8 oxygen 8 w latest driver (used to control the trigger plugin) pt10 just installed the usual DB and prefs trashed when I boot up PT10 for the first time I get an error message that reads... the original midi device associated w the midi controller m-audio keyboard could not be located please choose an existing midi device in the midi controller section of the peripherals dialog. when I go investigate the midi controller section and attempt to reselect the m-audio midi device it CRASHES pt10 everytime. as stated above i attempted to uninstall and reinstall the current m audio driver and also trashed the usual prefs. oddly enough when I try to use the controller via a midi cord plugged into my euphonix mc control (not via usb) and I try to assign the euphonix midi port via the midi controller section it also crashes pt10. any help would be appreciated |
Re: PT10 crashes when attempting to assign m-audio midi controller
as it turns out any time I try to change ANY assignment under the midi controllers tab it crashes the program. Just tried to assign the midi ports on my interface (m audio lightbridge) without any luck so..
oxygen 8 via usb crashes euphonix mc control midi ports crashes m audio pro fire lightbridge midi ports crashes |
Attempting to connect microphone through Scarlett 2i2 w/PT10.3.0 on W7 | madrona | Windows | 3 | 01-27-2013 09:42 AM |
can't assign midi controller issue (faderport) | alexruimy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-04-2011 02:09 PM |
Attempting to record audio track crashes Pro Tools SE | kiwi800321 | Pro Tools SE and Essential (Win) | 2 | 12-10-2010 09:09 AM |
PT8-crashes attempting to open consecutive sessions! | lownotesinc | Pro Tools TDM Systems (Mac) | 3 | 12-11-2009 12:36 AM |
PT 8.1 crashes when attempting to import audio | Andling | Pro Tools M-Powered (Win) | 1 | 09-05-2009 07:38 PM |
