tempo change on pro tools 6.7
Hi, is it possible to change the tempo of a track or whole session in version 6.7 LE. When I bought the upgrade I was told that this was possible much the same way you can speed up or slow down a track in ACID Pro. I've spent hours to no avail, this is not a midi track either, I need to speed up a whole session because we recorded it at a tempo that was too slow. Thanks
Re: tempo change on pro tools 6.7
Someone misinformed you.. you can change the tempo in 6.7 and the regions will shift (if their tracks are tick based).. but there won't be any automatic TCE.
Rail
What is TCE and basically you are saying this cannot be done. Also is there a plug in or any other program that works with pro tools that you can do this in. Thanks
TCE= TimeCompression and Expansion.
Its an Audiosuite plugin you could use to timexpand/compress your mixdown if you like the sound. Can use it track by track if you like the sound. or you can set everything up in Abelton live if you like that sound. Or if you own Acid, I heard its possible to rewire it now. if thats the sound. Or get that band some coffee and kickemindabut. Playin slow. Jesus. Sorry I΄m just givin you a bad time. I guess pushing sound together might even sound better than pulling it apart. But you know, I really dont know. Glad I could help tho. j |
Pro Tools 11 region selection not moving with tempo change | Skytouch | Pro Tools 11 | 0 | 12-22-2013 12:12 AM |
Pro tools 10 tempo change problem | hanzzi | Pro Tools 10 | 2 | 02-22-2013 05:20 AM |
Pro Tools 8.4 Audio/Tempo Change | jigga66 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-07-2010 11:19 AM |
Change Tempo Pro-Tools 8 | Simsy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-28-2008 03:22 PM |
Does pro tools automatically change the tempo?? | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-04-2008 04:04 AM |
