  #21
Old 10-13-2016, 12:52 PM
conleec conleec is offline
Default Re: Cannot Edit Clip Effects in PT 12.6 HD
What plugins are everybody who is seeing this problem using?
I'm using Melda Dynamic EQ, Pro Expander, and Pro Compressor on the tracks I'm working with. Could it be something to do with any of these, or a combination?
Chris
  #22
Old 10-13-2016, 04:22 PM
kkfaudio kkfaudio is offline
I've only got a trim plugin on the track I'm working on, but goes through halo, pro limiter, fab filter.
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
  #23
Old 10-14-2016, 09:34 AM
Hmm, I was hoping there would be some clue there, since it seems to be intermittent for folks.
Chris
  #24
Old 10-16-2016, 12:41 PM
smurfyou smurfyou is offline
Just had this happen during my first gig on 12.6.
Clip FX just won't respond to changes. I used it once. I could copy and paste the Clip FX but that's it. It also captured the keyboard until I closed the panel. Which I had to do with the menu command because the keyboard was in limbo... very frustrating.
~Will
  #25
Old 10-16-2016, 12:49 PM
I wish those of us who are experiencing this could figure out what our setups have in common, because apparently some people are not seeing this. It's super frustrating, because I can already tell it would be very helpful in my workflow to have it working. But right now, it's worthless.
Chris
  #26
Old 10-16-2016, 02:45 PM
I was on a deadline so I couldn't really take the time to dive into it. But it was frustrating. Literally the first time I've tried Clip FX for a real session. I think I had a Channelstrip on the inserts at that time.
Trashcan
PT 12.6
OSX 10.9.5
HD Native
Kona 3G
~Will
  #27
Old 10-16-2016, 03:07 PM
jpellizzi jpellizzi is offline
Same issue here. 12.6 HD Native on a 5k iMac.
First real session with 12.6 and it seems like I can only use the middle 2bandskd EQ. Nothing else responds.
  #28
Old 10-16-2016, 04:14 PM
Even that is interesting, because I can only adjust the the HP filter; so even what gets locked out differs from machine to machine. Very weird.
Chris
  #29
Old 10-16-2016, 07:51 PM
Interactivesound Interactivesound is offline
I'm also having this issue. I found some parameters I have to click towards the upper left of the parameter, just outside where I would expect to click. Some, like the LF Shelf/bell selection seem to almost never adjust... but i did get it to click a couple times. This is 12.6 on OSX 12.9.5 PT HD
  #30
Old 10-16-2016, 09:47 PM
mattrixx mattrixx is offline
I have also seen a number of strange things happen with clip effects. Some times, the parameters are not editable and sometimes they are. Have not discovered a valid reason.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Clip Effects Freezing Carl Lie Pro Tools 12 3 10-05-2016 04:24 AM
Clip Effects - Compression Metering?? off the wall Pro Tools 12 8 09-30-2016 09:59 AM
Clip Effects Enabled by default cshaw Pro Tools 12 0 09-30-2016 08:52 AM
Clip effects not working [SOLVED] cshaw Pro Tools 12 5 09-30-2016 05:22 AM
Issue dropping more than one clip into the Edit Window with Clip Transparency ON arb232 Pro Tools 12 0 02-10-2016 06:01 PM
