Old 03-02-2011, 11:04 AM
Goldencd Goldencd is offline
Default Quick keys or Shortcut for Mute?
I know that in PT 9 on OSX you can assign new shortcuts in system pref. Has anyone had any luck doing this and in specific assigning one for "Mute"?
thanks.
GoodLook Ent.
Mac Pro quad 2.66 (2010) - OSX 10.6.5 - 4g ram - Apogee Rosetta 800 - xHD - Neumanm Tlm 49 - Great River 500nv - LA2A - Protools 9HD
Old 03-02-2011, 04:49 PM
lexaudio lexaudio is offline
Default Re: Quick keys or Shortcut for Mute?
Are you talking about muting a region or muting a track.
To mute a region, command + M
To mute a track, track needs to be selected, Shift + M
Same with solo.
LEX
Old 03-02-2011, 06:34 PM
Same with solo.
LEX
I was talking about muting a track. I had no idea it was that easy. Any idea if I can map it to a number on the numeric keypad? I am looking for a easy way to mute and record at the same time... so "3" and "mute mapped to a number" so I can bypass the minimal latency that Avid still seems to screw third party Interfaces with.
GoodLook Ent.
Old 03-03-2011, 09:58 AM
iyaron iyaron is offline
Same with solo.
LEX
Do you use quick keys? Seems liek a great idea and SOS has an article in their recent extra issue but I am looking for simple how to....?
Everyday Is A Good Day
http://www.bandmix.com/itzhak/ My Music
www.itzhakyaron.com
Old 03-03-2011, 12:04 PM
Quick Keys are great! The problem with that Mute method is when SHIFT is selected, "3" on numeric pad does't trigger record or quick punch. So have instant "mute" or Ghetto Monitor input select (since avid won't give us the real thing" is not possible.
Everytime I think I find something that will work, I get road blocked. More and more it seems the only option is back to HD... but what will thunderbolt bring and is it worth holding out to see?
I would really like to keep my apogee conversion.
GoodLook Ent.
Old 03-04-2011, 08:31 AM
xbook xbook is offline
Quickeys could do this for you no problemo. Here's how I would program it:
step1:
Keystroke Macro
SHIFT-M
step2:
pause
0.2 seconds
step3:
CMD-SPACEBAR
Also prior to the Step1 you could throw in a SHIFT-R to have the shortcut put the track you are selected on into record ready. If you do though, I would also suggest a .1 second pause before the SHIFT-M.
You can choose which keystroke triggers your shortcut in Quickeys, and even restrict it to only working in ProTools. That way you can still use your number pad in other parts of the OS normally. If you do end choosing 3 over on the 10key, it will override the PT function of that key, so you know.
If you want I can write that shortcut out for ya, and send it. Startly, the guys who make Quickeys offer a 30day demo of the app if you want to check it out.
Blah blah blah....grumble grumble....woo hoo woo hoo.....dig it?
Old 10-24-2020, 10:54 PM
ReynaldoPena ReynaldoPena is offline
I don't know if it's because I'm on Pro Tools First or what but I use Command + M and the regions do not get muted. Can anyone help?
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 10-26-2020, 04:33 AM
What operating system are you using?
If OSX have you turned off keyboard shortcuts in system preferences?
Pressed some keys now shortcut keys wont work (T,R to zoom etc) Falcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-11-2016 10:49 AM
Auto Rename & Sort By shortcut/quick-keys? juan@jbi Pro Tools 9 5 08-15-2012 06:37 AM
Can't turn off Mac Function keys/turn on PTLE Shortcut keys b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-25-2009 09:15 PM
Track Record Enable/Mute/Solo shortcut keys? maufau Pro Tools TDM Systems (Mac) 2 07-06-2008 10:11 AM
function keys don't work as quick keys miked45 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2003 10:32 AM
