Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 06-08-2001, 02:51 PM
PSI PSI is offline
Default D24...............What happened to it ?
I m just about to buy my first TDM Pro Tools system and was wondering what happened to the d24 Protools solution, 32 tracks is enuff for me but I dont currently see it offered in their product line up. Does any one know if their are any Known disavantages to purchasing a d24 system and if so please inform me .
Thanks in advance.
Old 06-08-2001, 07:33 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: D24...............What happened to it ?
I'm sure some dealers still have some of these in stock, we just aren't making new ones, so it's not on the current Products list.
A couple things I can think of, but they haven't kept thousands of people from doing a lot of good work on the original Pro Tools|24 systems.
There are some plug-ins, like Virus, a few Waves plug-ins, and maybe others that require a MIX card because they use chips that are on the mix cards that aren't on the original pt 24 cards. Most plug-ins do run on a Pro Tools 24 system, though.
The original Pro Tools|24 only allows using DirectConnect as part of the new “RTAS on disk tracks” feature in Pro Tools v5.1 or higher, and requires a MIX card to be used as a TDM plug-in.
Bruce Paine
WebAdmin
Digidesign Customer Service
Administrator
Old 06-08-2001, 09:46 PM
uno1234 uno1234 is offline
But you can simply add a mix farm later for a simple, relatively inexpensive upgrade.
....right?
Old 06-08-2001, 10:38 PM
Avid's Avatar
Administrator
Sure, that's a benefit of the PT|24. You can just add a MIX Farm (for a lot less than a MIX Core) and the farm becomes a MIX Core with the presence of the original d24 card. Or you can do a number of different hardware exchanges, like trading in the DSP Farm for a MIX farm.
Bruce Paine
WebAdmin
Administrator
Old 06-09-2001, 06:02 PM
PSI PSI is offline
Thanks Bruce.
Old 06-09-2001, 09:26 PM
Peter Steinbach Peter Steinbach is offline
Hi Bruce-
I'm sure you've answered this before, but just to be sure: If I have a D24 card, and add a mix farm, do the voices increase to 64? Thanks in advance, PS
Old 06-10-2001, 11:58 PM
Avid's Avatar
Administrator
Yes, a MIX Farm card with the presence of a d24 card makes the MIX Farm act exactly as a MIX Core, with 64 voices and any of the other features you see listed in the Products section for a MIX system. Adding another MIX farm to a d24/MIX Farm combo would give you a MIXplus. The d/24 card is capable of being used for additional I/O, and some of the processing, like the mixer.
So the drawback is that it takes another PCI slot without being able to give much more plug-in power. But of course that is offset by saving a lot of money on a MIX core. If PCI slots are an issue, then there is still the more expensive option of trading in the d24 for a MIX core.
Bruce Paine
WebAdmin
Administrator
Old 06-11-2001, 12:17 PM
duffy duffy is offline
Bruce,
Could you elaborate on the DSP issue of adding a mix farm to the d24. ie. percentage that you gain vs. what is availible.
Thanks,
duffy
Old 06-11-2001, 04:02 PM
ProdInfo ProdInfo is offline
A MIXFarm has 2 to 3 times as much processing power as a DSP Farm, depending on the plugins one uses. The Pro Tools|24 system comes with a single DSP Farm, so if you were to add a MIXFarm, you'd have quite a bit more power- something like 2 or 3 more DSP Farm's worth. Also, as Bruce has mentioned, you'd gain quite a bit of track count and be able to run certain newer plugins that take advantage of the greater power in the MIX chips.
George Cochrane
Product Specialist
Digidesign
Old 06-11-2001, 09:19 PM
Thanks George,
I interpreted Bruce's as there wasn't much more DSP gained for plugs but you got more track count.
duffy
What happened to the...? Ludicrous Speed Pro Tools M-Powered (Win) 2 10-21-2005 07:45 PM
Need help!! never happened before DEEJAY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-29-2005 03:47 PM
What happened to 5.2.1 ???? curve666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-10-2003 07:09 PM
Has this happened to you? Logan M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-08-2002 12:45 AM
What happened??? RLB Digidesign Hardware & Software 4 07-14-2002 08:16 PM
