Old 12-04-2010, 02:24 PM
SmokinBaldMonkey SmokinBaldMonkey is offline
Default MP3 Option - Expired? My Serial is valid!
Recently I moved from my old mac to my new one. I did not do a typical migration, opting to clean-install everything from scratch.
However, I did not put in the MP3 option serial code, and used the demo instead due to convenience. I didnt want to dig through the closet at that particular moment for the old registration materials.
Now the demo expired.
So, my question is, once a MP3 demo expires, how does one enter in the MP3 Option serial number? ProTools doesn't even ask for one now, it just tells me "Sorry, your expired."
I am using version 8.1cs2 PTHD on a Mac Pro 8core, 10.6.4.
There has to be some simple solution to this....
Veni, Vidi, Funki - I came, I saw, I laid the stank down
System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO
System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 12-05-2010, 03:01 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: MP3 Option - Expired? My Serial is valid!
MP3 auth is now ilok, try your Avid account see if there's a way to enter the code and apply for ilok version. i can't remember if this is available to do in the account or not. otherwise you'll need to contact support.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-05-2010, 06:29 AM
mattrussell mattrussell is offline
what chris said and also, be sure you only have ONE instance of the "MP3.bundle" installed. if you moved some things around/did some new installs, you may have with more than one which would cause this kind of trouble.
good luck and let us know how it works out.
http://www.gainstructure.com
Old 12-05-2010, 11:34 AM
rockridge98 rockridge98 is offline
This happened to me last year when I switched computers.
I contacted Avid support, gave them my original license code,
and they sent a license to my ilok account.
Old 12-05-2010, 06:11 PM
nst7 nst7 is offline
You could also upgrade to PT9 where the mp3 functionality is standard.
Old 12-05-2010, 06:49 PM
velvettone velvettone is offline
Get the thing moved over to iLok. It doesn't make any sense to spend $350.00 (PT9) just to be able to continue to use $100.00 worth of software that you already own.
Old 12-05-2010, 06:53 PM
Obviously I wasn't suggesting that he do it only for that reason.
The serial number you entered is not valid tunetown Pro Tools 9 10 11-30-2010 04:04 PM
Mp3 Option Expired? rqstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-24-2009 11:38 PM
MP3 Option purchased.. code not valid ohgodhelp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2007 07:23 PM
Paid for MP3 option and only get demo expired window! Logic Pro Pro Tools M-Powered (Mac) 1 03-21-2007 03:04 PM
MP3 Option-Demo Expired-No option for aut. code desdichadisimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-10-2006 02:24 PM
