Old 08-09-2000, 07:58 AM
Rob Raden Rob Raden is offline
Default G3 - Sleep!?! What gives?
My mac puts itself to sleep even though I've removed the energy saver control panel! Am I missing something!??
Are there any other background deamons I need to watch out for to keep my PT happy?
Old 08-09-2000, 08:23 AM
Studio Dweller Studio Dweller is offline
Default Re: G3 - Sleep!?! What gives?
I have a G3/266 and it has done the same thing in the past. Right now, it's behaving properly. I'm running OS 8.6 and I have the energy saver control panel active, but sleep set to "Never". I imagine you've tried that, but maybe just try reactivating the control panel and setting it to "Never" again.
Larry Bentley
Cellar Dweller Productions
www.cellardweller.com
Larry
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 08-09-2000, 08:27 AM
DigiTechSupt's Avatar
We have seen some funky behavior with Energy Saver. I would suggest enabling Energy Saver in your current extensions set and setting the slider to "Never".
Brent
Avid Audio Tech Support
Support FAQ
Old 08-09-2000, 11:25 AM
Grey Grey is offline
I have seen this same thing...
G3/300 just freezes all by it self
sometimes I'm not even using it
grey
Old 08-09-2000, 01:29 PM
Robert U Robert U is offline
I don't know if I agree with you, Chris...
I'd set the control panel to "never sleep" and then removed it. After while my Mac "went to sleep".
I put the panel back and now my G3 never sleeps!!!!!
Robert Uhlmann
www.extensivemusic.com
Old 08-09-2000, 03:11 PM
Avid's Avatar
Avid Avid is offline
Administrator
Barnabas:
You are correct in almost all cases, but Robert U is correct in this case. Removing or disabling the Energy Saver Control Panel causes the Mac OS to use the Energy Saver default settings, which will put your mac to sleep after a few minutes of inactivity.
Have the Energy Saver control panel active in your Pro Tools extensions set, with sleep set to Never.
Bruce Paine
eMarketing
Administrator
Old 08-10-2000, 12:44 AM
Barnabas Barnabas is offline
Removing a control panel does not disable the feature, it just keeps you from being able to change the settings. So, as others have said, restore the control panel, change the settings, and then you can remove it (or disable it in Extension Manager)
Chris Droessler
www.barnabas.com Barnabas MultiMedia
Sleep my Mac Muzoid Pro Tools TDM Systems (Mac) 3 08-31-2006 08:57 AM
sleep hkx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-18-2004 12:19 AM
Sleep OS X and .001 ? guitates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-08-2004 03:25 PM
Can't Sleep in OS X yardo Pro Tools TDM Systems (Mac) 7 05-21-2003 12:33 AM
Sleep JoeTools Pro Tools TDM Systems (Mac) 0 05-20-2003 01:09 PM
