Old 08-03-2019, 10:47 PM
indeloon85 indeloon85 is offline
Default Plugins still resetting to their default parameters
Something I keep running into is the act of plugins resetting to their default parameters randomly. Yes, this does seem to have some correlation to the preference “plugins default to automatable parameters” (or whatever the preference is called).
I used to think this only had to do with some Waves plugins (CLA Mixhub, and Scheps Omni) but I’ve noticed it today with a plugin alliance plugin the BAX EQ.
I used to ALWAYS leave this preference on as it streamlines automation, though in the past few releases I have been having this issue. I’ve trashed prefs and a few other things (Thanks to the Pete Gates app) but this was not a solution.
It makes recalls super frustrating and slows down work. Anyone else have this issue?
Old 08-04-2019, 02:24 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: Plugins still resetting to their default parameters
I personally haven’t seen this happen or had an issue with what you are out lining. May be you might like to post your setup and the processes you are using leading up to these issues.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 08-04-2019, 02:45 PM
Absolutely! My computer is a 2018 Macbook Pro 2.9ghz I9, 32 gb ram. Currently running PT 2019.6 Ultimate on 10.14.5 (i know this isn't approved though it's been happening on previous releases that both PT and the MacOS were approved).
What really sucks is that it happens at complete random. It will happen during stripped down sessions with just a couple of tracks and plugins, then it will happen with much bigger sessions as well. It doesn't happen all the time, so it's hard to say how to recreate it. I've noticed this on a handful of plugins (Scheps Omni, CLA MixHub, and now the BAX EQ). I will open the session and 1 or more plugins have reverted back to their default state.
Old 08-04-2019, 02:52 PM
Following up, a session that I opened yesterday that had this issue, I just opened today after trashing prefs/protools.plist/ & AAE Prefs, and the plugins seem to be fine. This is with the "plugin parameters auto enabled" turned off and on.
Old 08-05-2019, 05:22 AM
xrekcor's Avatar
Hopefully that has sorted the issue because I would think plugin parameters are written to the session file. And it seems a weird thing to be happening.
Rob
Old 08-05-2019, 10:27 PM
It kinda seems like it has, though I’m curious how this would become an issue and how I can prevent it from happening again.
Pitch II parameters resetting themselves... volkgti90 Pro Tools 12 0 04-16-2019 10:13 AM
Dynamic Delay keeps reseting the parameters to default! in_stereo AAX Plug-ins 14 02-23-2016 09:47 PM
Sends default to -inf preference...resetting all sends to 0 Nathan W. Post - Surround - Video 3 07-15-2011 12:10 PM
TL space Parameters default reefer Pro Tools TDM Systems (Mac) 3 02-02-2005 09:17 AM
Resetting Plug-In parameters DannyVanSpreuwel ProControl, Control|24, Command|8 2 05-19-2000 12:28 AM
