Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-31-2010, 07:47 AM
ProToolsRules ProToolsRules is offline
Default PT 7.4 with Ozone Keyboard worked fine for 4 months until yesterday
Hi
I have been using my MPT 7.4 for some time now, out of the blue it gets stuck during loading i/o paths, this is a empty project btw, it also can not see recent sessions to open them, any help appreciated.
Below is a report
Process: cvmsComp_i386 [198]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_i386
UID: 502
Thread 713ab7c DispatchQueue 100
User stack:
9 ??? (in cvmsComp_i386 + 4969) [0x2369]
9 llvm::CVMSMemoryManager::getDlsymTable() const + 4112 (in cvmsComp_i386) [0x52b6]
9 mach_msg_server + 610 (in libSystem.B.dylib) [0x97d69632]
9 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib) [0x97cfd8e6]
Kernel stack:
9 ipc_mqueue_receive_continue + 0 [0x210aa3]
Binary Images:
0x1000 - 0x6ffb cvmsComp_i386 ??? (???) <837E8835-FA6C-0533-85EF-B0A1CDE589C6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_i386
0x97cfd000 - 0x97ea1feb libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
Process: cvmsComp_x86_64 [191]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_x86_64
UID: 212
Thread 6d3fb7c DispatchQueue 1
User stack:
9 ??? (in cvmsComp_x86_64 + 2740) [0x100000ab4]
9 llvm::CVMSMemoryManager::getDlsymTable() const + 3295 (in cvmsComp_x86_64) [0x1000035ed]
9 mach_msg_server + 539 (in libSystem.B.dylib) [0x7fff8194818e]
9 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib) [0x7fff818cae46]
Kernel stack:
Binary Images:
0x100000000 - 0x100005ff7 cvmsComp_x86_64 ??? (???) <00A29B78-A800-DF69-8C10-6E2BAF75F260> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_x86_64
0x7fff818ca000 - 0x7fff81a88ff7 libSystem.B.dylib ??? (???) <526DD3E5-2A8B-4512-ED97-01B832369959> /usr/lib/libSystem.B.dylib
Process: cvmsServ [99]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
UID: 0
Thread 6d2d3d4 DispatchQueue 1
User stack:
9 ??? (in cvmsServ + 4100) [0x100001004]
9 ??? (in cvmsServ + 23081) [0x100005a29]
Kernel stack:
Thread 60cb3d4
User stack:
9 thread_start + 13 (in libSystem.B.dylib) [0x7fff81903e41]
9 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff81903f8e]
9 ??? (in cvmsServ + 16132) [0x100003f04]
9 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff819059ee]
Kernel stack:
9 semaphore_wait_continue + 0 [0x22a0a5]
Binary Images:
0x100000000 - 0x100008fff cvmsServ ??? (???) <6200AD80-4159-5656-8736-B72B7388C461> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
White iMac 24"(iMac6,1) C2D 2.33 GHz, 2GB RAM,
Snow Leopard (Latest)
M-Audio Ozone keyboard
M-Powered Pro Tools 7.4,
Focusrite 26 i/o,
Korg padKontrol,
DynAudio BM6A's
Old 01-31-2010, 08:49 AM
audiogeekzine audiogeekzine is offline
Default Re: PT 7.4 with Ozone Keyboard worked fine for 4 months until yesterday
From the sticky at the top of the forum
http://duc.digidesign.com/showthread.php?t=147797
Delete Pro Tools preferences.
-Go to Users > “your user name” > Library > Preferences
-Delete 'com.digidesign.protoolsLE.plist', 'DAE Prefs' (folder), 'DigiSetup.OSX' and 'Pro Tools preferences'.
-Empty trash, then restart the computer.
You can also use the Pro Tools Preference and Database Helper to trash preferences and databases automatically, as well as providing a few other useful tools. (This application is provided by a 3rd party and is not tested or supported by Digidesign)
Repair Permissions
-Quit Pro Tools and launch Apple's "Disk Utility" application, located in:
MacHD>Applications & Utilities.
-Select your boot drive (the whole drive, not the volume underneath the drive)
-Go to the 'First Aid' tab and select "Repair Disk Permissions"
Apple recommends doing this any time you install new software, update your OS or reinstall any software.
Delete Databases and Volumes
This step can be useful when receiving random 'assertion' or 'neoaccess' errors, especially when recording or saving.
-Delete the "Digidesign Databases" folders on the first level of all mounted hard drives.
-Delete the "Volumes" folder:
Pro Tools versions 7.3 and earlier it's located in MacHD > Library > Application Support > Digidesign > Databases.
Pro Tools 7.4 and higher will find it in MacHD > Library > Application Support > Digidesign > Databases > Unicode.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 01-31-2010, 09:51 AM
Repair Permissions
Thank you for the prompt response.
Did everything, waited an hour for PT to load everything as the first time again and then i realized Pro Tools did not like the name of my Hard Drive, it had a (") in it to signify the size of the screen, i wish you had that in your help docs., i think that was the problem.
Focusrite 26 i/o,
Korg padKontrol,
DynAudio BM6A's
M-Box 3 Mini Not recognized. Worked for 2 months... therussell1337 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-06-2011 01:45 PM
Sessions were fine yesterday, now plays back in wrong pitch rawbe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-21-2010 10:38 AM
s/pdif light blinks, no audio signal, .. and it worked yesterday. Ensemble and Mbox TheSetup Pro Tools M-Powered (Mac) 3 09-05-2009 11:58 AM
Registered Mbox 2 Yesterday, 6 Months later The President General Discussion 1 01-09-2009 11:21 AM
Help Pro Tools Won't Launch - Worked fine yesterday mnoxious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2007 10:17 PM
