Old 03-01-2014, 01:33 AM
Rockman413 Rockman413 is offline
Default PT drops recording issues
Hi , I'm using Pro Tools to record like 100-200 channels at one time, while PT is in slave mode (when master tells it to start, then it starts to playback and record). Sometimes I met the occasion that Pro Tools suddenly stops sync&recording and then starts to playback in sync without recording.
This occasion is mainly because of CPU spike? (I monitored that CPU is not high at all)
or disk too slow? (I had a raid 0 of 2 disks , which I think it's fast enough for recording 200 channels)
or some plugins I used are taking too much CPU?
or sync via MTC has this issues....
Thanks
Old 03-01-2014, 11:29 PM
Pythagor Pythagor is offline
Default Re: PT drops recording issues
Did you try to increase freewheel parameter?
Old 03-02-2014, 08:12 AM
Actually I have no idea what this is .... Is it have something to do with the problem I had? The bigger the better?
Old 03-02-2014, 10:35 AM
It is number of frames Pro Tools doesn't care for incoming TC drop. Look at Session Setup window
Old 03-02-2014, 06:39 PM
Will see! Thank u !
Old 03-02-2014, 06:58 PM
reichman's Avatar
reichman reichman is offline
Dumb question, but do you have transport and audio track record lock engaged in preferences? PT might be more reliable doing this if it doesn't need a specific REC command...
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 04-29-2014, 04:15 AM
Did you try to increase free wheel parameter?
I set it to 120...and there's still drop recording occasionally... However, change into jam sync will never stop recording.
I understand what does the freewheel means...but it looks like 120 is not enough for me.
1. A way to set it higher than 120?
2. Will Jam sync cause not in the sync/ or in wrong time position if I played it for a long time?
3. I didn't meet drop while playing back in syn cmode, only in recording ....which part could be wrong? not enough CPU because recording costs more CPU?
Old 04-29-2014, 11:55 PM
i would try to record on two separate disks instead of RAID
Old 04-30-2014, 02:47 AM
If your master causes TC-dropouts that are as long as 5 seconds I'd rather fix the master generator than using even higher flywheel settings. 120 frames of flywheel is a huge value in that context.
Are you sure are getting problematic TC for that long?
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 05-03-2014, 06:45 AM
I used only 1 disk
HTML code is On
7.4.2 Audio level drops and Issues with Core Audio misterwine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-08-2008 08:14 PM
Using ADC while recording - any issues? Siegfried Meier Pro Tools TDM Systems (Mac) 19 11-26-2007 02:57 PM
About 2 minutes into recording audio drops out? smattsav 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-15-2004 12:26 PM
AI3 drops out while recording matt vallo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-19-2002 02:14 PM
Recording Punch: Audio on other tracks drops out! SteveU 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-15-2002 01:47 PM
