Old 06-30-2002, 02:04 PM
bp78 bp78 is offline
Default Difference between motion sensitive and touch sensitive faders?
I know it has been touched on before,but I couldn't find the thread. Please explain the difference between the fader sensitivity of the Control 24 and Motor Mix. Thankyou.
Old 06-30-2002, 04:55 PM
PTLance PTLance is offline
Default Re: Difference between motion sensitive and touch sensitive faders?
The C24 faders start writing info as soon as you touch the fader. The Motor Mix only starts writing info after you have moved it.
Old 07-01-2002, 05:18 AM
Richard Fairbanks Richard Fairbanks is offline
For instance, with a touch sensitive fader you can simply touch it to stop it. With motion sensitive you have to grab and move it which changes the level in the best case and which can be a real problem if the fader is already in motion. Touch sensitive is much better.
Call me by my real name, "Postman"
Old 07-02-2002, 01:13 AM
Thanks for the replies. Motor Mix users: Can you reply as to your personal experiences--Pro and Con?---Thanks
Old 07-02-2002, 01:18 AM
The JL Cooper 3800 is touch sensitive. Are there any 3800 users who could offer their feelings about the unit?--Thanks
Old 07-02-2002, 11:28 AM
mattpete's Avatar
mattpete mattpete is offline
If you press the SHIFT button on the Motor Mix, it will drop any track that's enabled for automation writing into write. It's not as graceful as touch-sensitive faders, but it does work. Also, I've found that you can let your fingers "ride" the Motor Mix fader without causing it to write and at the precise moment you need to punch in on the automation, you press the SHIFT button. It's really hard to do that on a fast moving touch-sensitive fader (you can't "ride" the fader without going into write.)
-Matt
Matt Peterson
Avid Audio
Old 07-03-2002, 02:09 AM
Thanks Matt--so I take it that you're satisfied with MotorMix for the mostpart?
Old 07-03-2002, 09:27 AM
mattpete's Avatar
It's pretty cool for such a small box. But it's not as nice as a Pro Control!
Matt Peterson
Avid Audio
Faders on 2 units instantly no longer touch sensitive SVElbert Artist Series 2 03-19-2013 07:56 PM
Non touch sensitive faders quick fix before I contact Digi? macaholic ICON & C|24 4 06-24-2009 08:54 AM
Are the rotary encoders touch-sensitive... Stig Eliassen ICON & C|24 2 07-31-2008 08:53 AM
Mackie Control "Touch Sensitive"? d8b is a Joke... a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-13-2004 02:53 PM
touch sensitive faders CharlieAoun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-10-2003 06:22 AM
