Old 10-01-2008, 10:19 PM
Atardecer Atardecer is offline
Default ProControl and Fader Packs suddenly offline
All of a sudden we seemto have lost communication with our procontrol unit and fader packs. We can still work and all audio is being passed correctly but PT simply refuses to detect the units. Going into the periphereals dialogue i can re-enable our ethernet controller and it is recognise but i cant select any of the units as they are simply not there. We havent changed anything in our setup and the ethernet controller seems to be functioning fine. Just seems to have happened for no reason! Any ideas?
Thanks,
James
PT HD2 7.3.1cs4, 192 I/O Dig X 2, 192 I/O, 96 I/O, Sync, ProControl w/Edit Pack, FaderPack X 3, Intel Core2 6600, 2GB, Asus P5WDG2 M/board, WinXP SP2
Old 10-02-2008, 08:25 AM
DigiTechSupt's Avatar
Default Re: ProControl and Fader Packs suddenly offline
Have you tried power cycling everything?
Which 'ethernet controller' are you referring to? A hub? A switch? Have you tried resetting it?
Does it work if you connect the ProControl main unit directly to the computer?
Avid Audio Tech Support
Support FAQ
Old 10-02-2008, 05:37 PM
I will try connecting directly to the computer to see if it makes a difference however we have been using it for the past 6 months connected to a hub with no problems. Dont understand why it just disappeared. Also we need to have our computers networked and we can only do this via the hub. Ive tried power cycling all the units, rebooting, re-enabling - nothing seems to work. When i say ethernet controller i mean to say that in the peripherals dialogue it correctly recognises the onboard LAN controller its just that it doesnt recognise the units. So it doesnt seem to be a problem with the LAN controller or drivers.
Thanks,
James
Old 10-03-2008, 08:55 AM
I completely understand that, however, it's akin to saying 'I've been driving my car for the last 6 months with no problems' when you get a flat tire. Things happen and we need to eliminate the variables to determine what the source of the problem is. Taking components out of the chain will help narrow down what the ultimate cause of the problem is.
I've seen many cases where the LAN controller is recognized, but it still causes problems. Sometimes it's a defective controller - a component fails, but not one that would cause the card not to be recognized, or possibly a driver gets corrupted, but not in a way that affects recognition of the card by Pro Tools.
Support FAQ
Old 10-15-2008, 11:09 AM
Hmm, i will check to see if it works properly connected directly to the onboard LAN and not via the hub when i get back to the studio. The fact that our other devices and operations connected to the hub are working fine (ie. Muse Receptor, Networking both computers) would suggest that the controller's drivers/firmware are OK? Need to keep investigating...
Thanks,
James
TRADE: ProControl Main Unit and 2 fader packs janmuths Buy & Sell 16 05-18-2015 01:15 AM
Looking for ProControl Fader Packs and Edit Pack BassBuddha ProControl, Control|24, Command|8 6 01-31-2011 01:47 PM
C24 Suddenly Offline COCO ICON & C|24 3 11-30-2004 11:23 AM
Fader Packs? funkdefino ProControl, Control|24, Command|8 7 05-12-2004 08:45 PM
Extra Fader Packs nozza1 ProControl, Control|24, Command|8 4 07-20-2001 11:21 PM
