Old 02-06-2008, 02:57 PM
beggehorn beggehorn is offline
Default Play 24 bit files in Windows Media Player!
Hey all,
Just stumbled across this today and am amazed at how simple this solution is. I've run it on my production system and it works perfectly.
Just download this:
http://www.chrisnet.net/msdn/AudioTypeConvert.zip
You will need to copy the AudioTypeConvert.ax file somewhere onto
your system and manually register the filter using regsvr32. E.g. if you
copy it to C:\Windows\System32 then, at the "run prompt" you would type:
regsvr32 c:\windows\system32\AudioTypeConvert.ax
To disable it if you have a problem, at the "run prompt," type:
regsvr32 /U c:\windows\system32\AudioTypeConvert.ax"
Cheers!
Windows 10 Pro x64
Avid HDX running PT Ultimate 2020.x
ASUS WS x299 SAGE 10g
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
Old 02-13-2008, 04:42 AM
Atardecer Atardecer is offline
Default Re: Play 24 bit files in Windows Media Player!
Ive been using winamp for this purpose. Great for quickly previewing files thru your HD system without the need to fire up tools. Works fine with 24 bit.
Cheers,
Jim
PT HD2 7.3.1cs4, 192 I/O Dig X 2, 192 I/O, 96 I/O, Sync, ProControl w/Edit Pack, FaderPack X 3, Intel Core2 6600, 2GB, Asus P5WDG2 M/board, WinXP SP2
Can't Play Windows Media Player after PT installation? ovenbakedbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-22-2008 02:06 PM
Bouncing to WAV - won't play in Windows Media Player Room335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-10-2007 01:31 PM
Bounced WAV files won't play in Windows Media Player 11 DHaining Pro Tools M-Powered (Win) 2 11-09-2007 09:11 PM
Windows Media Player still wont play chahende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-20-2005 03:59 PM
Windows Media Player won't Play Jburn34 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-11-2003 08:47 AM
