Old 09-27-2007, 10:42 AM
GeneOuse GeneOuse is offline
Default New session and disk allocation
Call me an idiot but there's one thing that pisses me off lately about protools so I'll just ask it and you tell me if I have a valid point or if I should just shut up (sorry for such language).
Let's say I create a new session called "Hit Song 1" and then go into the disk allocation settings and make sure that the audio files go into the newly created folder for this session. I create a new audio called "Loop1" and record 1 bar loop. When I go into the audio folder I see a file called Loop1_01.aif. Ok, everything seems normal.
Now, let's create another new session called "Hit Song 2" but this time I won't touch the disk allocation settings, I'll just make a new track called "Loop1" and will record a 1 bar loop. When I go into the new folder for this session the Audio Files folder doesn't even exist but all audio goes into previous session folder.
I don't even know how to express myself here but this really gets me. I'm not a robot so I do forget to set disk allocation for a new session many times, but I though that's why we have computers, to do things we can't or forget to do. Isn't it logical that when I create a new session things get saved in the place I just created UNLESS I SPECIFIED it differently?
DIGI, why not include disk allocation settings in the new session menu? I know I can fix scattered files session by using "Save Copy In" option but I don't want to do this.
What happens is I will backup a session and delete it from local drive only to find out that I had 4 different session storing audio files into the session I just got rid of, so I need to waste time fixing that and wonder if there are any other session that will pop up with the same issue later on.
Another cool thing that could happen is by giving my client a backup archive I could give some copyrighted label material away not even knowing that it's there and you never know what can happen to it.
Anyway, I said it, I was actually really nice about it but when I had to spend hours fixing things (and it's not the first time) I wasn't happy at all.
Old 10-03-2007, 01:03 AM
Atardecer Atardecer is offline
Default Re: New session and disk allocation
I totally agree with you. What makes it even worse is that templates on a PC do not seem to work AT ALL so to start a new project with your template you have to import session data (our template has 32 tracks monitoring a separate Nuendo system). If templates worked then i suppose i wouldnt have to think about disk allocation. The problem here is that when im not in the studio and the composer is on their own, they end up saving stuff in god knows what folders. If i try and explain disk allocation to them their eyes just glaze over and rightly so - they shouldnt have to think about those things. I guess i am used to using Cubase where such a thing is not even a consideration. Please digidesign can you sort this out? Pretty please?
Cheers,
James
PT HD2 7.3.1cs4, 192 I/O Dig X 2, 192 I/O, 96 I/O, Sync, ProControl w/Edit Pack, FaderPack X 3, Intel Core2 6600, 2GB, Asus P5WDG2 M/board, WinXP SP2
Import Session Data : Disk Allocation midnightrambler Pro Tools TDM Systems (Mac) 7 08-13-2010 09:20 AM
Does "Save Session Copy In" set disk allocation? Seeee Pro Tools TDM Systems (Mac) 5 03-14-2007 09:07 AM
The original disk allocation for this session cann hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-20-2006 11:18 AM
Disk Allocation Problem -- PT Session can have two disk allocations?? tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-26-2003 07:22 AM
disk allocation/ session template?? Flunky5 Pro Tools TDM Systems (Mac) 4 08-07-2001 01:04 AM
