xxxxx unreadable by Pro tools
I've searched the DUC for the answer, but can't seem to find one.....sorry if this is a redundant question:
I have a client that posted SD2 files to an Apple iDisk. When I download them and try to import audio to my session, I get the xyz is unreadable by ProTools When one of my production partners loads the same file from the iDisk to his MOTU DP system, he has no problem I cant even launch them in Quicktime player Any ideas? I'm on Mac OS 10.4.8 PTHD 7.3 running on a G4 dual 1Ghz |
Re: xxxxx unreadable by Pro tools
the resource fork has been striped somewhere along the way.
he ether needs to put a zip shell around the SD2's or better yet use BWF
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thank you for your response.
How do I explain other people being able to use the files upon download? Is it something specifically that my system is doing to the file? I always use BWF. These tracks are coming in from a client who used SD2. They will be imported and converted to BWF which is what my sessions always run in. |
Hey Jim
If they don't have the .sd2 suffix to the file name, try adding it manuall.. then try to re-import them into PT. For some reason, .sd2 files don't travel well on the 'net. The idea of stuffing/zipping them on the sending end is a good one, since un stufing/un zipping on your end will alwayw work.. Good Luck |
.wav is unreadable by Pro Tools | M577 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-31-2008 02:35 PM |
Unreadable by Pro Tools... | redbearddread | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-19-2008 02:55 AM |
Wav is unreadable by Pro Tools 6.4 | crabkillers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2005 06:38 PM |
.CDA Unreadable by Pro Tools: HUH? | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-04-2003 06:50 AM |
de xxxxx.cda a xxxxx.wav | Eddiex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-19-2003 06:09 AM |
