Old 11-17-2004, 03:43 PM
Tubthumper Tubthumper is offline
Default Uses for Behringer BCF2000 control surface in PTLE
I've had my 002R system up and running on an Allenstein for a few weeks now. It's one powerful recording tool but frankly, I work on PCs all day and therefore have no desire to come home and spend several more hours fiddling with a mouse - cordless or not, we humans aren't meant to be assuming one position for hours on end.
So, I need a control surface....can't afford a Command8, and would rather spend $440 AU dollars on the Behringer BCF2000 than over $1000 on a Mackie Baby HUI or CM Labs Motormix. BUT, I want to be able to use the control surface for the most common functions that I presently carry out with the mouse.
I've heard that the BCF2000 will allow me to control faders and transport functions without having to use the mouse. Anyone know if I can also work with plugins directly from the BCF2000?? Any other stuff I can use it for?
Thanks people.
Old 11-17-2004, 09:25 PM
Default Re: Uses for Behringer BCF2000 control surface in PTLE
Pretty sure it will control transport and fader/pan but I don't think it does plugin control.
Old 11-18-2004, 04:37 PM
Bumpity bump
Old 01-17-2005, 07:21 AM
Puustinen Puustinen is offline
Please people tell me that the BCF2000 will work with the PT LE 6.7 Or I have just spend 250$ for nothing...
MBox 1 Factory
HP nw8440 laptop with XP Pro SP3, 3GB RAM: dverb test 90
Desktop XP Pro SP2, Q6600 2.4 GHz, 2GB RAM: dverb test 158
3 TB storage space
PT LE 8.0
Alphatrack
Focusrite Liquid Mix
Waves Musician II, NPP bundle (Native)
DUY EverPack, IK-Multimedia plugs, Nebula 3, apTrigga 2, and so on..
Old 01-17-2005, 08:02 AM
Third Eye Studios Third Eye Studios is offline
Here's a link to a post where someone wrote how they got that controller working Controller . It works with HUI emulation I believe (the HUI driver installs with 6.7 I think) and you have to download the latest firmware from behringer's website.
Old 01-17-2005, 09:46 AM
Here's a link ... the HUI driver installs with 6.7 I think
Thanks for the link. I read somewhere (I can't find it anymore) that the pre-installed HUI driver is the main reason why the BCF2000 wan't work on the 6.7 as there is no way to use third party drivers
All the people who have 6.4 don't have any problems using it but I found this link where Edwin (using 6.7) says the following: "It only talks to PT in baby hui mode and only through physical MIDI ports (ie, not USB)".
That would mean that it wouldn't work for as I only have MBox
I just hope this is not true...
MBox 1 Factory
3 TB storage space
PT LE 8.0
Alphatrack
Old 01-17-2005, 10:11 AM
Here's some more links I found searching this forum:
USB/Midi
more BCF 2000 via USB
In this one the user says they have it working with an m-box. Maybe try contacting them.
Good luck!
Old 01-17-2005, 11:54 AM
Good luck!
Thank you very much! The help was really needed. Using the search function I found the thread I was looking for. The problem doesn't seem to be BCF related, instead it's looks like a bug in the 6.7 conserning MIDI OUT to third party hardware. Go figure
Now I know that I won't be updating to 6.7 until that is fixed.
PS. Tubthumper, I'm sorry that I "loaned" your thread. I will answer your question when I get the machine and have it up and running.
MBox 1 Factory
3 TB storage space
PT LE 8.0
Alphatrack
Old 01-17-2005, 11:58 AM
Wow, just make a wish and it comes true. 6.7cs6 . Maybe next time you should wish for money.
Old 01-17-2005, 12:08 PM
Maybe it's not too late, I wish for a lot of money to all of you DUCers out there
MBox 1 Factory
3 TB storage space
PT LE 8.0
Alphatrack
Help With my Control Surface! BCF2000 with PTLE 8 Alexrkstr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-04-2009 05:42 AM
Behringer BCF2000 B-Control Fader LaForestPoetry18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-05-2005 01:58 PM
Behringer BCF2000 controller with PTLE 5.2 on OS9? clarity1285 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-31-2005 08:37 AM
Behringer B-CONTROL FADER BCF2000 PlainJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-16-2004 08:04 PM
Pro Tools LE with Behringer B-Control (BCF2000)? headwerk'n 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-10-2004 02:20 PM
