Old 08-11-2004, 08:01 AM
CraigD CraigD is offline
Default Quick Key Command for Transport Window???
Does anyone know the quick key command to open the Transport window on Pro Tools 6.4 with a Powerbook G4 OS 10.3.5?
I use to press ctrl + Option 1, that doesn't work now. All it says I can use is Option 1, on a numeric keypad only.
Thanks~!
Old 08-11-2004, 01:21 PM
DigiTechSupt's Avatar
Default Re: Quick Key Command for Transport Window???
Do you have a Function Key? It should be in the lower left-hand corner and be labeled fn. Try using Command>fn>J/1. When you use the fn key it toggles the keys on the keyboard to act like the numeric keypad I think J is also 1 in most cases.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Old 06-09-2011, 04:56 PM
joeldadrummer joeldadrummer is offline
Sorry to bring up an old thread. but I can't figure this out at all.
i use a mac pro, and I've tried Funtion1, command Funtion1 , all sorts of stuff.
what is the quick key for the transport window in PT9?
www.joelfountain.com
Old 06-09-2011, 05:17 PM
Craig F Craig F is offline
numbers on the number pad (ten key) not the ones above the QWERT
command+1: Transport
command+2: Session Setup
command+4: Automation
Thank you,
Craig
Old 06-09-2011, 08:02 PM
I love you
Old 06-18-2015, 04:22 AM
khushalbhadra khushalbhadra is offline
Yeah command + 1 doesnt work, however since the Bluetooth keyboard doesn't have a Numpad. How will it work in that case? Also how to use it in the case of a Macbook Pro?
Transport Window and Color Selection window lost cd_audio_mix Pro Tools TDM Systems (Mac) 6 11-26-2006 10:58 PM
D-command transport Igotsoul4u ICON & C|24 5 08-09-2005 07:11 AM
how to put transport window inside edit window? keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-18-2004 06:47 PM
Anyone awake? Quick transport ? mjames08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-10-2004 09:38 PM
Command+1 not showing transport window?? Jared3 Pro Tools TDM Systems (Mac) 1 09-29-2000 10:16 AM
