#111
Re: Pro Tools 2022.9 "Saving ARA Data"
I would reinstall Protools at that point. Looks like something is corrupted unless this is the only project where this occurs. If so I would save a copy of the project under a new name then use the new version and start looking at various plugins i.e. delete then reinstall them as one may have corrupted the project or maybe a clip didn't get saved correctly.
That's all I got. Good Luck. |
#112
Infuriating! |
#113
I think I have discovered one thing that is helping to keep this from happening in the first place. Every time before I put Melodyne on a clip, I render the clip (command-shift-3) so that Melodyne only imports that small segment. If you don't do that, then Melodyne will be imported for the length of the original size of the clip even though you may not choose to ever edit any of the rest of the clip. So, if you have a comped track pulling from lots of playlists, when you make Melodyne active on that track, it will import Melodyne for the full length of the original clip for every clip you use in that comped track. That is a ton of Melodyne data and it seems that once Melodyne reaches a certain threshold, it starts doing this "Saving ARA Data" thing. It is definitely smart to consolidate the comped clips before you instantiate Melodyne on it. I am also constantly rendering the clips when I am done and turning Melodyne off as much as possible after my edits. These are not ideal ways of working with Melodyne in Pro Tools, but they have been somewhat working as a workaround for me for now until there is a fix.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#114
Avid responded to my case that I opened about this issue:
"A fix is coming for it but I don't have any specific time frame for the following Pro Tools delivery, however we can keep an eye to this page for next releases: https://avid.secure.force.com/pkb/ar...-Documentation on the Release Notes specifically is where can check the bug fixes" |
#115
I haven't tested it yet, but according to the Release Notes for the out-today (Oct 25) PT 2022.10...
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
#116
Release Info says:
"Reduced the frequency of the 'Saving ARA Data' progress bar (PT-289968)" This sounds not really good to me. I hoped this will gone and not reduced. Does this mean that saving ARA data has to interrupt the workflow? That's why I don't update PT. I had a similar issue with Studio One that forced me to stop working with the S1. |
#117
So has 2022.10 sorted out everyone's problems on this? Because I'm still getting slow saves here.
#118
Im not sure. It definitely is less frequent. But I have moments where the computer really locks up which I am assuming is coming from this. It doesn’t say “saving ARA” though when it happens.
#119
The ARA saving is definitely reduced. If you’re on a Mac I suggest a co-install of 22.9 and 22.10 if you’re worried about the latter working for you. Easy enough to jump back and forth to compare versions with the same session.
#120
On 2022.10, Win 10 pro 21H2. Comped the vocal to another track using"Quick Punch", consolidated the new track, tuned with Melodyne and rendered. Easy, peasy!
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? | ZerglingPhilosophy | Getting Started | 1 | 09-02-2022 03:43 PM |
"Error, missing PACE authorization" with PT 2022.4 and iLok USB Key [FIXED 5/27] | DaveGross | Pro Tools | 56 | 05-27-2022 09:05 AM |
Pro Tools not importing volume with "import session data" | lapieuvre | Pro Tools 12 | 4 | 10-16-2015 06:02 PM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
Pro Tools LE and "Import Session Data"? | lydpik | Tips & Tricks | 5 | 09-11-2009 05:12 PM |
