  #21
Old 03-11-2011, 04:04 AM
tamasdragon tamasdragon is offline
Default Re: Pt 9.0.2
Regarding stability, this release rocks! Pro Tools 9 is very-very stable here from day one, and this release is not an exception.
I'm glad!
my blog:Tamas Dragon
  #22
Old 03-11-2011, 09:50 AM
WKG WKG is offline
I'm glad!
I agree.
There are always going to be some quirks to get ironed out but I am really liking PT 9 so far.
  #23
Old 03-11-2011, 11:00 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default
Originally Posted by John_Toolbox View Post
Downloaded, but I'm not going to install it for a while since everything is working right now.
Ditto this for me.. + the fact I'm seeing that they screwed with the Grid.. & really, the only issue I hav is the 'Quickpunch-pop' which is driver related so I'll stick with 9...
Sent from EPIC 4G using Tapatalk On'eim...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
  #24
Old 03-11-2011, 02:04 PM
DigiTechSupt's Avatar
Keep in mind the grid 'problem' may not be a factor, depending on how you work. You can still see grid lines by using Slip+Grid and move things off the grid by using holding 'command' while click-moving the region.
Avid Audio Tech Support
Support FAQ
  #25
Old 03-11-2011, 03:10 PM
True which is how I really work.. (Ctrl+click in grid mode) butttt, I'll 'hole~up a sec still
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
  #26
Old 03-11-2011, 03:23 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
So far, so good. I'm knocking on every piece of wood I can find.
  #27
Old 03-11-2011, 04:28 PM
TOM@METRO's Avatar
Sure you can work around it, but it was nicer when it worked as designed. Much like the Autosave function. I hope we see a fix on this before the next dot release.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #28
Old 03-11-2011, 06:07 PM
Trainwrecker Trainwrecker is offline
I think I am skipping this one. I was hoping for some major upgrades for third party interfaces. There are some real issues shared with many brands like the "Interface not found" bug.
For me, that they messed the grid lines give me major pause. I wonder what else has been overlooked? I will wait for the verdict. I really do like PT9 though.
  #29
Old 03-11-2011, 06:30 PM
25ghosts 25ghosts is offline
After install my whole system would NOT recognize my inserted ilok. Reinstalling the pace driver did NOT do the trick. A few restart and parameter rams later PT finally accepted my ilok...
Then I had something that I usually dont have with PT... Crash after crash after crash. In fact PT crashes to often the past 4 hours than it did the past half year in my setup....
NOt say it is PT but it all went south after running the update.
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
  #30
Old 03-12-2011, 12:00 AM
TOM@METRO's Avatar
I hope you imaged your drive first as suggested at the start of this thread. Just roll back if you did.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
[IMG] code is Off
