Mac G5 Dual 2.3 (PCIX) OS 10.5.8 PT8.0 + SCSI What Card Works?
Hi I have a
Mac G5 Dual 2.3 (PCIX) OS 10.5.8 PT8.0 I have an ATTO Express PCI Pro UL3D I have installed the driver. But it does not work. Digidesign's site identifies the UL4D as compatible with the G5. I've seen a few mentions on the web about the adaptec 29160. I'm confused. Everything I've read either says that the G5 is the problem or 10.5 is the problem. Some say I can run the ATTO with 10.5 on the G4. Some say It will run on the G5, but only with 10.4. I don't want to buy the wrong card. Should I get the Adaptec 29160? There seems to be a few versions of these, Which one runs on the G5? What about 10.5? What about the ATTO UL4D? Same questions, will it work on the G5 with 10.5.8? Thank you for any help, Bill Williams |
Re: Mac G5 Dual 2.3 (PCIX) OS 10.5.8 PT8.0 + SCSI What Card Works?
I have an ATTO Express PCI Pro UL3D in a G5 Dual 2.0 + Mac OS 10.5.8 + PT HD 8 and I have an ATTO Express PCI Pro UL3D in a Dual G4 1.25 + Mac OS 10.4.11 + PT HD 7.4, both systems are working fine
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
can you tell me what versions of drivers and configurations utilities you are using? I have having trouble getting my UL3D on a G5 with 10.5.8 to work.
Thanks, |
I use ATTO Configuration Tool 3.06 on both G4 and G5.
Make sure you use the PCI slot farthest away from the graphics card, so the top slot of your G4/G5. As driver I use ATTO ExpressPCI Plus 3.20 I also use ATTO Configuration Tool 3.06, my settings are identical for both Channels: Common NVRAM Configuration Controller ID: 7 Termination: Auto Selection timeout (ms): 16 PCI Burst Rate (bytes): 128 Reset Bus on Startup: Enabled Wide ID's: Disabled Fallback Sync Rate (MB/s): 20(10) SCSI Target NVRAM Configuration Specified Target: 0 LUNS: 0 to 7 Allow disconnect: Disabled Tag Command Queuing: Enabled Sync Enabled for this ID: Enabled Sync Offset: 62 Sync Rate (MB/s): 160 DT Wide transfers: Enabled ATTO prefers SCSI drives with an ATTO driver installed, but it also works fine with SCSI drives formatted by Apple's Disk Utility (HFS or HFS+)
Re: Mac G5 Dual 2.3 (PCIX) OS 10.5.8 PT8.0 + SCSI What Card Works? I use ATTO Configuration Tool 3.06 on both G4 and G5.
Make sure you use the PCI slot farthest away from the graphics card, so the top slot of your G4/G5. As driver I use ATTO ExpressPCI Plus 3.20 I also use ATTO Configuration Tool 3.06, my settings are identical for both Channels: Hi, I downloaded and installed the most recent driver v 4.43 and configuration tool 3.38 and flash bundle 2009_04_10. Then after reading your post, I found and downloaded Driver 3.21 and config tool 3.07. Config tool 3.38 did not work at all. But Config tool 3.07 did recognize the card. However, when I tried to install the 3.21 driver, the previous driver 4.43 still showed installed. I'm not sure if the flash worked or not. Questions: 1) were you using the UL4D or the UL3D ? I have both cards now. 2) do you have the drivers that you list above? I could not find those exact drivers on the internet. 3) would you send them to me? If so you could email to [email protected]. 4) Do you know how to uninstall the 4.43 driver so that I can start fresh with the lower number driver ? I think I'm getting close to getting this to work ! Bill Williams |
2+3) mail was sent with all I have from ATTO attached 4) if I remember well a newer driver will be replaced by an older driver I hope this can help you out...
standard pcix core card with accel pcix | pie55 | Pro Tools TDM Systems (Win) | 1 | 02-08-2012 03:33 PM |
Which graphics card works best in G5 AGP (dual 1.8), Protools HD 8.01 | rantanplan | Pro Tools TDM Systems (Mac) | 4 | 03-28-2011 04:38 PM |
OEM Atto Scsi EPCI-UL2D Card ($49) works for me ! | sebi | Pro Tools TDM Systems (Mac) | 1 | 01-14-2003 02:37 PM |
New 867 Dual Processor need help with Scsi Card | KasticK | Pro Tools TDM Systems (Mac) | 3 | 11-05-2002 04:07 PM |
Dual 867-I want a scsi card, which one is the best? | Footprints | Pro Tools TDM Systems (Mac) | 7 | 10-11-2002 09:09 PM |
