Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 06-07-2012, 08:41 AM
johnpastry johnpastry is offline
Default Headphone mix ?
Hi everyone,
I'm starting to work on a Pro Control with 192 interface and Protools 9 hd but I can't manage to get a headphone mix up and running.
The talkback works but not the feedback.
I know I'm missing something basic but can't see what it is.
If the talkback works, it means that the problem is not in the headphone patch but in the IO patch..?
I'd appreciate any help possible
Thanks
Old 06-08-2012, 09:51 AM
francois's Avatar
francois francois is offline
Default Re: Headphone mix ?
tricky without reading the manual: page 18 to 22 on the PDF :
audio connections
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 06-08-2012, 11:13 AM
As the connections were made when I got in the studio, and they never had any problem of this kind whatsoever, I guess I didn't watch this side.
My male db 25 is set on audio input 2 instead of input 1, could that be the cause of the whole thing ?
Thanks
Old 06-08-2012, 12:30 PM
francois's Avatar
yes the cue ins are on 7/8 of input 1
On input 2 you have the Main ins on 7/8
Old 06-11-2012, 03:08 AM
I tried to switch from input 2 to input 1 but there was no sound in speakers as well so i put it back to input 2
I looked at my outputs, the output 6 goes to my headphones and on Protools I created an output HP on same output, I see the signal on the table going out of 6 but still no sound.
I tried every options on the control room buttons
What am I missing ?
Thanks a lot
Old 06-11-2012, 03:41 AM
update: I'm on a surround session, but only two speakers are working, on output 7-8. the others dont.
when i plug output 7 to headphones i have sound
Old 06-11-2012, 08:19 PM
francois's Avatar
Dear John
RTFM !!!
We can go back and forth forever .
Page 18 to 22 Have the diagram you need .If you want Headphones and surround sound you need to use both DB25 inputs as well as the DB25 output .
I took a snapshot of those page diagrams for a quick reference ,it's not logic so i need to refer to it every time i repatch my setup
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-12-2012 11:34 PM
headphone amp tuffy21 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-01-2005 11:05 PM
OT - headphone amp euphjazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-16-2005 03:24 PM
headphone mix MR808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-19-2003 11:29 PM
Headphone Impedance and the 001 Headphone amp Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-15-2002 12:22 AM
