Sidechaining with Avid Pro Compressor
Hello,
Can anyone provide me with some guidance about the Compressor settings for sidechaining ? Best
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.3 Pro Tools 2024.3 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
Re: Sidechaining with Avid Pro Compressor
Every case is different. What are you trying to achieve? I would start with the default settings
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
the Pro Compressor has got a lot of additional variables .... I am just trying to make the kick stands out from the bassline ... I also added you on Avid Link
This can be done with any compressor that allows side-chain. The "usual" method is to insert a compressor on the bass track. Add a send to the kick track to an open bus and select that same bus as the side chain input in the compressor. The idea is to have the kick drum trigger(fast) the compressor so that the bass gets pushed(downward) out of the way of the kick drum attack(so start with fast attack and release and tweak from there). I put "usual" in quotes as there are no rules, only guidlines
Got a question regarding sidechaining, most plugins I have only let you sidechain either left or right channel, so I have to use 2 or the plugins and set the key input on one to right, and the other to left. Is there some easier way to do this and sidechain left and right channel with one compressor?
Insert the plugin in normal stereo
To clarify, you will be using the compressor insert as a stereo plugin but the key input will be mono as PT doesn’t allow for stereo busses as sidechain triggers. There was some talk about this recently on the forum, but for the majority of people, this isn’t an issue. Just set your send to be mono. It doesn’t matter if your trigger track or track being compressed is stereo. Sent from my iPhone using Tapatalk |
FS: Avid Pro Compressor + Pro Limiter | reneo | Buy & Sell | 0 | 12-22-2018 02:39 AM |
Avid Pro Compressor vs. Dyn III Compressor | Nick Camaron | AAX Plug-ins | 3 | 09-17-2018 10:07 AM |
Favorite compressor for sidechaining to a kick? | leftalive | AAX Plug-ins | 9 | 11-15-2017 07:40 PM |
WTB: Avid Pro Limiter & Pro Compressor | danander11 | Buy & Sell | 0 | 04-22-2015 04:27 PM |
WTB: Avid Pro Compressor & Pro Limiter | Funkmasta69 | Buy & Sell | 0 | 12-04-2014 06:59 PM |
