Xpand 2 "Out of Range"?
I'm working on a project on which I use Xpand!2 on 7 tracks. On the 2 of them, below the clip name in the edit window it says "Out of Range."
What does this mean? Is this something I should worry about? |
Re: Xpand 2 "Out of Range"?
Hmmm, never seen that, but I don't do tones of Xpand stuff. It may be that the midi notes are above or below the range of the "patch" used in the plugin. Maybe try transposing up/down and octave(or two) and see what happens
Thanks--I've never seen it either. I'll try that, although everything seems normal with those tracks (they sound as they should).
I must sheepishly admit that I don't know what the numbers below the clip name represent. |
A quick guess....are they the start and end time of the clip?
I don't think so. It may have something to do with regions, but I can't make sense of any pattern.
Looking at the project I'm working on, the vocal track says vocal 0/4/830 120/3/947 and the bass track says bass DI 0/4/830 123/4/290 (I've made the common numbers red). But other tracks have completely different numbers. I have no idea. |
http://duc.avid.com/showpost.php?p=1101521&postcount=2
Region Says "Out Of Range" “The session start time is later than the region's time stamp. You can either change the session start time or turn off the Region timestamp display in the View menu.”
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 |
Thanks for weighing in.
Are there pros and cons for changing the session start time or turning off the display? |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Creative Content Collection "*.big" files MIDI Xpand!2 | Adekyn | macOS | 6 | 09-03-2011 08:58 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
error msg "your equipment isnt installed properly" after xpand update | yanncrusoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2008 03:55 PM |
"Quantum Range Recording Process" | Arno Peeters | Tips & Tricks | 1 | 08-12-2002 06:21 PM |
