Old 06-23-2009, 10:09 PM
b4vylon b4vylon is offline
Default Re: Control 24 set up
Originally Posted by stainless View Post
BN4vylon
I'll jump in
since the original post is/was quite old
are you connecting to a hub? or directly to your PC? If your PC has multiple ethernet connections make sure that they are set-up on the computer (I'm now on a Mac and it's been 3 years + so I don't recall the exact protocols for this)
are you using the correct ethernet cable (not one left over from your modem?)
IF/when you go to peripherals, and select the port, if Control 24 is showing up (meaning the computer "sees" it)... the problem is a software problem and you need to find the correct/current software version
and it sounds like a software issue (the good news)... the bad news is you have to go find the correct firmware (I believe this to be true)
i try... i let u knows is work properly
Old 06-30-2009, 11:37 AM
hi everey one...
i still with the problem.... i cant enable the ethernet controllers for C24.... the same error...
http://lh4.ggpht.com/_0UyyvNtGAVw/Sk...128/image1.jpg
http://lh3.ggpht.com/_0UyyvNtGAVw/Sk...128/image2.jpg
please any one helpme.... i need fix the problem...
Old 02-05-2011, 04:52 AM
rbhun rbhun is offline
hiya all
just solved my similar problem:
START AS ADMINISTRATOR!!!!
PT needs to be run as admin.. you should go into the recommendation section from Avid, tweaks for W7, and set the program to run as admin all the time.
My EditPack still wont work (error -43), but at least the other parts do.
Balazs
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 07:05 AM
How to control plugins applied to audio files with Artist Control ozu Artist Series 3 04-01-2013 02:36 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
