Warp or TCE to selection length?
I'm looking for a solution of warping files to a specific length. I've got a lot of audio files in 2 languages. E.g. Track 1 is english and track 2 german. The german clips begin exactely at the same position as the clips on track 1. These files are all time critical, so the german files have to be exactly as long as the english ones. So I'd like to select the english clip on the first track. Then jump down with this selection to track 2 and compress/warp the clip there to the lenght of the clip on track 1. I prefer a solution only with keys, so that I can automate the workflow with Quickeys, because I've got hundrets of files. Is this possible somehow? Or is there another way to get two different clips to the same lenght? Thanks, Michael |
Re: Warp or TCE to selection length?
HD only :
select english clip deselect link timeline and edit selection edit-select german clip Alt+Shift+U (TCE Edit to Timeline selection (Pro Tools HD and Pro Tools with Complete Production Toolkit only))
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Wohoo... this looks good. Working!
Just to be sure I'm doing everything right: By "edit-select german clip", you mean just click on the german clip to select it. And after each clip has been processed, I have to reactivate "link timeline and edit selection" and then select the next clip. Then I repeat the whole thing... Yes... sounds like a plan! |
i created a Quickeys workflow and i works fantastic! Thanks a lot! Michi |
Because a shortcut like "move edit selection down" would not select the "german" clip. So you programmed a mouse click ?
oh I missed your last answer. No, no mouse click needed. You can do it with keyboard shorcuts: Position cursor at the beginning of the english clip then: shift tab, shift keypad /, alt tab, Ö, shift tab, alt shift U, shift keypad /, tab, P, tab and you are at the next clip and then repeat the whole thing. By the way... Greetings from Munich |
Nice, that works.
Greetings back to Munich from Nymphenburg .
What a pity I have never heard of Quickeys workflow solution before!
It appeared so easy combining files for my tutoring classes! Thanks! ______________ essay dune blog |
Hotkey for double/half length of selection | jschmidtiii | macOS | 1 | 10-17-2013 02:20 AM |
Default selection length | MFPBand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-30-2012 04:09 PM |
Copied region length auto-adjust to paste location length? | greglawrence | Tips & Tricks | 4 | 10-23-2011 12:46 PM |
Moving Selection By Selection Length | weezerboy | Pro Tools TDM Systems (Mac) | 14 | 09-23-2010 03:06 AM |
timecode selection length - Pro Tools lies! | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 08-20-2009 10:01 PM |
