Old 09-17-2001, 04:58 AM
ROOM 12 ROOM 12 is offline
Default drum triggers/modules
Does anybody use triggers. I was thinking about buying a module and some triggers, what do you recomend. Also whats the deal with these sound replacer programs. Can I replace recorded drums with sampled ones. Thanks!
Old 09-18-2001, 08:46 AM
s.d. finley s.d. finley is offline
Default Re: drum triggers/modules
I just finished a project yesterday where i used a trigger on the snare for the first time. I purchased a Pintech trigger from musicians friend, $10. I already have soundreplacer.
Using the trigger and replaceing the trigger hit w/ a snare using soundreplacer was so easy i could not beleive i had not used it before.
I am thinking about triggering toms now too.
I had tried using SR w/o using a trigger on the snare, but bleedover presented such a problem that i had to buy a trigger.
I do not have a drum module, you do not need one. I am going to buy some drum cd samples now.
rock
sdf
sdf
sugarhillstudios.com
Old 09-18-2001, 10:10 AM
bassmac bassmac is offline
s.d.
Does the snare trigger give you all the varying levels of attack and velocity you get with a mic - or at least three as needed for SoundReplacer?
Old 09-18-2001, 11:21 AM
Bassmac, yes, the dynamics that the drummer gives to the snare is caputured by the trigger.Ghost notes and rimshots are a different situation. I also have 2 other mics on the snare,bottom and side, so i can blend all 3 together, and then blend w/ the overheads.
sdf
sdf
Old 09-18-2001, 11:40 AM
Thanks for the info. So, I really dont know anything about this SR program. Does it have its own drum sounds? Is there only 1 SR program? Sorry for all the Q's, I'm just tryin to learn.
Old 09-18-2001, 02:26 PM
Reply...no problem. There can only be one!
Sorry [img]images/icons/wink.gif[/img] , had to do it. I think there is only one SoundReplacer, its listed in the software section products.Its in plugins, its audiosuite only and Digi makes it. I do not even think that there is a similar program for VST or MAS.
It does not, or mine did not, come w/ its own sounds.
However, you can import sounds into it. Via a cd smpler of drumkits, or...you can find the best "hit" on the drum track and import it into SR's plugin settings. You could also have the drummer hit his drums after the take to get a good sample too.
A program like Recycle makes it even easier, to pick apart loops and take the sounds you want.
In SR, you can set 3 different thresholds for 3 different(or different sounds even) dynamic settings for the sound. IE, soft snare hit, medium sh, hard sh.
Its pretty ez to use, although not all the hits line up all the time, and if they are off, its usally by a few MS.
I just zoom in and drag the new audio to line up w/ a snare hit i am keeping.
hope this helps
sdf
sdf
Old 09-18-2001, 02:41 PM
the_riot the_riot is offline
Just in case you're still interested in an actual drum module, I thought I'd make my suggestion for the Alesis line, particularly the DM Pro. The quality of internal sounds on that thing is amazing, great for replacing any real drum sounds. Ever since the D4 many of them have become studio standards. The other perks would be that you could one day buy triggers or electronic pads and have a playable set, unlike software options. Not to mention the software for the DM Pro that allows you to import your own samples to a PCMCIA card for later use (live triggering, etc.) Hope this helps!!!
Old 09-19-2001, 06:22 AM
thanks!
Old 09-20-2001, 09:12 PM
IOP Drummer IOP Drummer is offline
Here's a great tip for triggering. Only use good triggers. Pintech will not do, get D-Drum. Yes they are more money but they will last FOREVER and never hurt any drum. They aren't even that much. Anyway, there's two scenarios for triggering. Live, and after the fact. For both I recommend that you plug the trigger RIGHT INTO A MIC PRE, then A)Compress and go to the sound module/tape machine or B) record the disgusting sound of the trigger itself. I recommend recording the nasty sound. It is SO easy to trigger that with soundreplacer it's incredible, and you easily get ALL of the dynamics as accurately as the drummer played them. I've never had 100 percent luck with triggering accurately live with any dynamics, especially when new at it. It is something I felt was changing the way I was playing just so it would trigger right, and that's not cool for me. For lack of decent outboard stuff I've never tried LIVE the trigger into a pre into a comp into the module into the PA scenario.
Mike Blanchard
Engineer
Old 09-20-2001, 10:24 PM
ThomCat ThomCat is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by the_riot:
Just in case you're still interested in an actual drum module, I thought I'd make my suggestion for the Alesis line, particularly the DM Pro. The quality of internal sounds on that thing is amazing, great for replacing any real drum sounds. Ever since the D4 many of them have become studio standards. The other perks would be that you could one day buy triggers or electronic pads and have a playable set, unlike software options. Not to mention the software for the DM Pro that allows you to import your own samples to a PCMCIA card for later use (live triggering, etc.) Hope this helps!!!<HR></BLOCKQUOTE>
Just want to add a "ditto" to this post. My only gripe with the DMPro is its a little tedious to audition the patches. The quality is as good as it gets, though...all 20 bit with cymbal crashes that ring for 5 seconds with no looping. And it's very well set up for 12 (or is it 16?) triggers. Since Alesis has gone down I'm not sure how hard they are to get now, though...I wouldn't sit on the fence too long.
Drum Triggers costas.themis The Drum Room 2 01-25-2012 03:12 PM
drum triggers?? bluesguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-17-2005 07:37 PM
drum triggers MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-10-2005 09:30 AM
midi drum triggers SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-09-2003 07:13 PM
drum triggers and sampled drum sounds SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-05-2000 11:11 AM
