Old 06-10-2008, 11:01 AM
eric22rr eric22rr is offline
Default Leopard / PT 7.4-PR / Command|8 not compatible?
I recently switched over to a new Mac Pro. I've been waiting for PTLE 7.4 to be compatible with Leopard, so now that it is... I installed just the pre-release version of 7.4 (since I didn't have any previous versions of PT on this computer -- i knew it wouldn't work.)
My problem is...
Pro Tools doesn't recognize the Command|8. Audio/Midi setup does, and even ableton Live recognize it as a midi device. However, the Command|8 always says "offline" when Pro Tools is running. Any ideas why?
Old 06-10-2008, 11:09 AM
DigiTechSupt's Avatar
Default Re: Leopard / PT 7.4-PR / Command|8 not compatible?
Did you configure it in the Peripherals dialog, per the instructions in the Command|8 Guide?
Avid Audio Tech Support
Support FAQ
Old 06-10-2008, 11:38 AM
Ha -- thanks, that was stupid of me... i forgot i did that when i set it up originally; plus, i should have read it before i jumped into the forum... sorry!
Is HDx recording compatible with Leopard? SlowTools VENUE Live Sound Systems 5 12-01-2008 05:02 PM
PT HD Now Compatible with Leopard... Tony Shepperd Pro Tools TDM Systems (Mac) 50 02-18-2008 08:53 AM
Pro Tools not compatible with Leopard - Same for the 003? RockGod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2008 09:12 AM
002 compatible with leopard & Vista? ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-04-2007 02:20 AM
Leopard OS Compatible? greatgearguy Pro Tools TDM Systems (Mac) 1 10-21-2007 01:11 AM
