\"All Notes Off\" controller in 6.9.3
After stop playback some midi instruments continue sounding. I think this instruments don`t receive "All Notes Off" controller on stop playback.
AnyOne tell me please what can I do in PT for fix it??? WinXP pro sp2 PT 6.9.3cs2 midi interface Motu FastLane USB 2 gb RAM
------------------------------------------------------------------------------------- Pro Tools 2018.4 Ultimate; Omni HD+HDX1 over Thunderbolt 2; MacPro 6.1 |
Re: \"All Notes Off\" controller in 6.9.3
In 6.9, I believe it is MIDI->All Notes Off.
I forget the keyboard shortcut offhand...when you drop that menu down and see that item, the shortcut appears right beside it.
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
ctrl+shift+.
that's all notes off. Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
Tnx.., I remember about Ctrl+Shift+.
During MIDI programming after each "STOP", some my MIDI instruments is continue sounding. If I will be press Ctrl+Shift+. each time, I will boring very soon.. But other DAWs (like Nuendo) send "All Notes Off" automaticaly after stop playback each time. And in Nuendo preferences I can turn off or turn on this function. But Pro Tools can`t doing this. Why? 2 Digidesign: You can insert this function in Pro Tools in the near future? Or in the nearest updatings?
Yeah- a definite must-have feature IMO
For what it's worth, I am not experiencing stuck notes very much in PT 7 HD. Very rare....and I use MIDI alot. M-Audio Radium61 via USB, and a Kurzweil via Digi MIDI I/O (via USB); not using external instruments much, if at all...virtual almost 100%.
Hi Nikki
Are you experiencing delayed midi notes (virtual synths mainly) when recording in advanced sessions? Me and Jules described it here It is still not clear for me are people at Digidesign aware of it. Can you confirm this bug too? Thank you |
But I will give it a try with a higher load...
I don`t know about PT 7.
2ALL: May be anyone use this function in PT 7? P.S. Если я не ошибся - ты Женя Петров из Русаудиопро?
This issue is partly a problem with the RTAS plug-ins themselves and should occur much less, if at all, in Pro Tools 7. Any issues in Pro Tools 7 are very likely a problem with the plug-in and would need to be addressed by the plug-in manufacturer.
MIDI Controller creating two of the same notes? | KAhlstrom | macOS | 4 | 05-21-2013 07:24 AM |
Moving Controller Data with Midi notes | Swar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-29-2009 09:38 PM |
Reason + MIDI controller = hearing notes twice??? | rippegari | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-01-2007 04:11 PM |
"All Notes Off" controller in 6.9.3 | BoRiZ KukoBa | Pro Tools TDM Systems (Win) | 0 | 10-10-2005 07:37 AM |
Double notes being recorded from controller keyboard? | flymax | MIDI | 1 | 10-06-2002 04:59 PM |
