Old 01-07-2006, 04:01 AM
Andi Andi is offline
Default digi001, ASIO drivers, Cubase
I've got someone interested in buying my digi001, who'll mainly use Cubase.
I've only read somewhere that it is possible, but as I've never tested it and don't have a copy of cubase myself, I'm asking for your experience.
Does it work, with all 18 I/O, as well as with non-digidesign hardware?
Any problems one might run into?
thanks,
Andi
Old 01-07-2006, 11:08 AM
Default Re: digi001, ASIO drivers, Cubase
^^ up
Old 01-08-2006, 03:15 PM
k, found some info, but if anyone wants to throw in their 2 cents, you're welcome
Old 01-08-2006, 05:28 PM
JMS40 JMS40 is offline
I've had a very limited experience with the combination.
I recently did some tracking at a Nuendo facility and
used CB as a go between for my Pro Tools setup. (CB opens Nuendo program/session files.)
I didn't do any recording with the setup. Only comping and consolidation and such on pre existing sessions. ASIO playback worked flawlessly, though, and all inputs seemed to be available.
Old 01-09-2006, 12:13 PM
Sir Bergersworth Sir Bergersworth is offline
yes it works just fine. I use my 001 with Nuendo all the time. works like a champ. I have never used the ADAT with nuendo, but all other inputs/ outputs work great.
"Miracles do happen, snowmen fall from the sky completely unassembled"
P4 2.0A-Intel 845GEBV2-1024 DDR-Radeon 7200
001-PT6.4LE-Nuendo-Reason
Help with ASIO Drivers for 003 rack - Cubase even not recognise..... gregers123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-18-2008 05:43 PM
Cubase not recognizing 002r ASIO drivers JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-15-2006 02:52 PM
Problems with ASIO drivers, Cubase SX3 with 002r fog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-12-2005 07:53 PM
anyone using MBOX ASIO drivers with CUBASE/LOGIC? tom_h 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-15-2003 10:43 AM
no asio drivers to cubase and a mixer to windows98? omen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-19-2001 05:39 AM
