Noise on knobs on Avid Fast Track Solo
Hi guys!
I have an Avid Fast Track Solo. When I turn up or down the volume pot, it makes an annoying noise. I read that one probably solution is to cleaning the pots. Anyone known how to do it? Thanks. |
Re: Noise on knobs on Avid Fast Track Solo
Spray a little electrical contact cleaner into the pot and move the pot back and forth rapidly - works for me a lot of the time. (disconnect the power first and let it dry a couple of minutes)
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Hi! Thanks for your replay.
I have to disassembly the interface to reach the pots, but I didn’t see any screw or how to do it. Could you help me please? Thanks again! |
I usually just remove the knobs and spray down the shaft of the pot and move them as mentioned. The can usually comes with a tube that fits into the 'cap' so you can concentrate aim......spray lots (flood them while rotating)....you can't hurt any electronics inside as the spray evaporates rapidly.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
As to taking the case apart I'd say look for screws hidden under any stickers or feet. |
Never had a problem with doing it the way I described.
As long as the little tube is attached to the sprayer, liquid is funneled into the tiniest of gaps with can pressure.....no over 'spray' anywhere. I don't think it makes any difference where pot is mounted since shaft leads to pot wherever it is mounted. No need at all to take case apart (bare in mind this often voids warranties) unless more 'all around' cleaning required. In any case, just do it whatever way spins your crank.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O Last edited by zedhed; 07-02-2018 at 09:32 PM. |
Hey!
Thanks all of you for your answers. I’m gonna try to fix the poblem with your advices and when I solve I post a reply here. Thanks a lot. |
I too have been doing this for a very long time and have never had to open any case up....and my gear is top quality, the gap is small, but it's always there. If it wasn't, the shaft wouldn't turn. I literally flood the pot so it gets everywhere inside, again, the little tube must be fitted to concentrate aim. The can pressurization forces fluid into tiniest of gaps. I'd suggest to the OP, try my way first because it's easier. If it doesn't work, by all means open the case up. .........over n out
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O Last edited by zedhed; 07-07-2018 at 08:47 PM. |
Avid Fast Track solo white noise | vinap1 | FireWire & USB Audio Interfaces (Win) | 7 | 04-26-2020 03:44 PM |
Random White Noise PT Express Fast Track Solo | mremming | Pro Tools 10 | 0 | 02-19-2016 07:36 AM |
Fast Track Solo White Noise | jg707 | FireWire & USB Audio Interfaces (Mac) | 3 | 01-15-2016 08:50 AM |
Avid Fast Track Solo | horrificsquid | FireWire & USB Audio Interfaces (Win) | 0 | 04-18-2015 04:16 AM |
Avid Fast Track Solo | Lombardi | FireWire & USB Audio Interfaces (Mac) | 1 | 09-09-2013 03:10 PM |
