Old 10-18-2017, 06:24 AM
koo_koo_bonkers koo_koo_bonkers is offline
Default Understanding an "in the box" dubbing workflow
I held off on upgrading so long I went directly from v7 to v12. Well I dabbled in v9 a bit on my laptop...
A hold over from v7HD cards I used to have my stems setup so they would cascade through audio tracks that were input enabled and fed my master bus. I could monitor as I worked and then print as required.
Earlier this year I setup v12.7HD Native (no avid hardware) with stems and master bus in the same old way as v7HD cards only to realise that there was a "known issue" where the stems would print a frame or two late if setup cascaded.
I'm trying to understand the issues better and I'm looking through the "Whats new" docs for versions 12.7 and up. Is this what "Blue mode" referrers to ? Is everyone just using the track commit feature for stems now ?
Currently I'm setup to use aux sends to feed my stems as a colleague recommended. I have also experimented with using track commit from my source busses which is a great new feature.
Any advice would be amazing ...
Thanks
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2
Old 10-18-2017, 08:31 AM
Dan Smith's Avatar
Dan Smith Dan Smith is offline
Default Re: Understanding an "in the box" dubbing workflow
This is exactly what blue mode is for, which is for HDX systems. However I follow the same procedure on my HD Native system and haven't found any delay on my printed masters. And it has been that way since before they released "blue mode." With delay comp turned off on those tracks I don't have any delay. All my print tracks are being fed by master auxes for each stem. I monitor through the input on my printmaster track. Track commit and offline bounce to multiple busses at once is really great but normally I'm printing and punching in, in real time.
Dan Smith
Re-Recording Mixer - Warner Brothers
HTML code is On
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
Needing a more analog "template" style workflow. Need advice from the PT sages... Matt Hepworth Pro Tools 11 6 07-27-2015 02:42 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
