Bussing a Stereo Track to Mono Aux: Summing change from 2018.3 to 2019.5
Hi All,
I just recently upgraded from PTHD 2018.3 to PT Ultimate 2019.5. I'm on Mac 10.12.6 Trashcan. I've noticed a change in how PT sums a stereo track that is bussed to a mono Aux. In 2018.3 (and before) if you bussed a Stereo track to a mono Aux, it would yield a +3db signal (due to the summing). In 2019.5, the same process yields a +6db signal. I am seeing this across multiple suites on HDX and Native. |
Re: Bussing a Stereo Track to Mono Aux: Summing change from 2018.3 to 2019.5
Wow.really? Oh no. Messes up recalls then from pre 2019.5
Sent from my SM-G975U using Tapatalk |
Could it be the pan law setting?
Possibly but the pan depth is set the same in both instances. So, they shouldn't be different.
Just saw your post and happened to be in in a studio with pt11.3.1. and also pt2018.12.0
So did the following check. Both have same result. If I put 1k tone (Created via audio suite signal generator which would make it a coherent source) on a stereo track at -20dB and then route that to a mono aux the result is -14dB on the mono aux. anyway hope the info helps Cheers Bruno Last edited by SBP; 06-25-2019 at 10:40 PM. Reason: Adding coherent detail |
I think everyone needs to be clear if they are testing coherent or non-coherent/incoherent sources.
A coherent source will sum to +6. This has nothing to do with pan law but everything to do with audio physics. An incoherent source should sum to +3. Basic calculator and explanation http://www.sengpielaudio.com/calculator-leveladding.htm
Hi Guys,
Thanks for this. Here are two screen shots of the same session. I am using a file for the tone made by the Audiosuite Signal Generator @-20. It is the same file for the left and right. 2018.3 Mono= -17 Stereo= -20 2019.5 Mono= -14 Stereo= -20 Given Bruno's results, maybe 2018.3 is the problem? |
Are the tones time aligned? Audiosuite tones are notorious for not starting the waveform exactly at the same point in time, so i would double check phase alignment
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
This is why I used the same file for both left and right. Only way to be sure. Regardless, I should get the same result in both versions of PT. |
From Avid Support:
The issue you reported is by a known issue with PT12.0 - 2018.3, which was fixed in PT2018.7. The current version is working properly and the previous versions (12.0 - 2018.3) did not... |
PT Summing Stereo Tracks to Mono - differences between PT10 and PT12 | buyonnet | Pro Tools 12 | 11 | 05-06-2017 01:17 AM |
Change a track from mono to stereo in PT12 | jamestr12 | Pro Tools 12 | 11 | 04-14-2017 05:13 PM |
Summing a stereo track to mono | scadh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-03-2010 02:16 PM |
SIMPLE Q' RE: Rec/bussing a stereo signal to mono. | Rudiebassic | Tips & Tricks | 2 | 10-29-2005 06:01 PM |
Bussing reverb - stereo or mono? | MidnightFlyer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-16-2003 02:34 AM |
