Old 02-02-2019, 02:26 PM
Siegfried Meier Siegfried Meier is offline
Default Digidesign 192 Digital & Apogee Clocking
Hey guys,
I have a 192 digital and 4 x AD8000 units here that I’ve got connected together for 32 io on an HD10 system. They are connected as follows:
2 connected via TDIF for 16 io
2 connected via legacy port and Digi8+ card on AD8000 for 16 io
Now, if i set all 4 Apogee units to their respective Ambus cards for sync, everything appears to work perfectly and I get no clocking errors. But, I feel like I should be using wordclock instead in some way but haven’t had any luck...lots of clocking errors...
Can anyone tell me the recommended way to clock these 5 units together?
Thanks!
Sig
Old 02-13-2019, 03:30 PM
Sugarnutz Sugarnutz is offline
Default Re: Digidesign 192 Digital & Apogee Clocking
Daisy chain them all with BNC cables starting with your master, either the 192 or one of the Apogees, then make sure the last unit in the chain has a 75 ohm termination resistor. That should take care of it.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Apogee AD-16X and HD I/O clocking issue track Pro Tools HDX & HD Native Systems (Mac) 7 04-18-2014 08:28 AM
Another Clocking question -- 192/SSL/Apogee greenwall Pro Tools TDM Systems (Mac) 3 07-05-2010 02:45 PM
Clocking to an Apogee Big Ben one 192 and a legacy alex3368 Pro Tools TDM Systems (Mac) 2 10-22-2006 01:52 PM
Clocking MIX system with Apogee AD-16 JNS Pro Tools TDM Systems (Mac) 4 04-04-2004 09:47 AM
Apogee Rosetta 800 clocking thin ice Pro Tools TDM Systems (Mac) 30 08-26-2003 09:18 AM
