Fade OUT to multiple clips one single track?
Is there a way to ad a fade out to multiple Clips on a single track?
When I selected them all and hit ⌘ F It ties to make fade ins as well which I do not want |
Re: Fade OUT to multiple clips one single track?
Sure you can. Cmd+F brings up the fade dialog, and there are also handy presets you can choose where one is called "Only fade outs". The length box is pre-selected, so just type what you want in ms and hit Enter.
Yeah but when I hit ⌘ F with all the clips selected it bring up the crossfade window and i can't type zero into my fade in. it won't let me
Which version of PT is this? Version 12.3 introduced way more flexibility with batch fades.
i Have 12.7
But I do not have the full keyboard with the number pad (just thought I would let you know that) |
The lack of a numpad doesn't matter. Select all clips > hit Cmd+F > to the right of preset numbers 1-5 it says "Factory default" > click that and select "Only fade outs".
Okay I will try that as soon as I get home tonight. Also, on the topic of editing multiple clips that are on the same track
Do you happen to know how to shorten the length of multiple clips that are on one track? I saw on this forum people said: -- Select the clips with the OBJECT GRABBER tool , then use -- [Option] +/– to trim clips' start -- [Command] +/– to trim the ends But that did not work for me. Does that command only work with the +/- buttons on the numeric keypad? |
Under factory settings it did not have that option... it only had this
cheers john
Is shuffling multiple clips together on one track really not possible?? | MVO | Pro Tools 12 | 5 | 09-04-2017 12:22 PM |
Adding Multiple Clips to a single track in Pro Tools | simonmatt | General Discussion | 4 | 04-23-2016 01:58 AM |
Fade Out Multiple Adjoining Clips | tangoportland | Tips & Tricks | 8 | 12-03-2015 03:04 PM |
Multiple midi clips to one track | Raoul23 | MIDI | 1 | 07-02-2015 08:01 AM |
Single track to multiple tracks or aux | realizment | Pro Tools 10 | 2 | 11-16-2012 11:28 PM |
