Use 192 with HDX?
Is it possible to use this combo with 1 HDX-card:
HD I/O 192 I/O 192 I/O 192 digital edit. Sorry, this one has been asked too many times I guess, and yes it still seems to work fine.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 Last edited by Firechild; 04-22-2020 at 10:29 AM. |
Re: Use 192 with HDX?
While Im not sure about your particular setup. [ you miiiiight be one interface too many?] I DO run: HD I/O 16x16 HD I/O 16x16 HD I/O 16x16 192 on one HDX card
Best, Sean Sean McDonald Red Medicine Recording LLC Sofa King Music Services http://www.seanmcdonald.com |
Isn't there a difference with latency between the HD and the 192? Also, can you hear a difference between the two interfaces? |
I would be very impressed if you could pick out which is which in a blind test. Golden eared mastering engineers can't do it reliably.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
I ran 2 of each for the past 3 years and all was fine. As for latency, that will only matter if you record the same source thru different converters. I never heard any issues with drum mics thru lightpipe(Midas XL-48) and overheads/hat/ride thru the HD IO analog Both interfaces are totally capable of making hits, depending on pretty much everything OTHER than the interfaces
