Old 04-19-2010, 03:43 PM
DJ Hellfire DJ Hellfire is offline
Question Plugin graphics (GUI) not loading/displaying properly???
Ever since 8, I've been having an issue from time to time where the plugin GUI will not load and the plugin isn't usable. It seems to happen when I have a decent amount of plugins loaded. I've noticed it mainly with the stock compressor and EQ III, Smack compressor, and if I use more than 6 instances of my Sonnox Limiter VST, it happens with that as well. And today, it started happening with Speakerphone. CPU usuage barely has a dent in it when it occurs. And it occurs with both the onboard graphics and my PCI grahpics card. Anyone else experience this?
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 04-19-2010, 03:57 PM
sw rec sw rec is offline
Default Re: Plugin graphics (GUI) not loading/displaying properly???
Try backing down hardware acceleration one notch from full right.
Right click on the desktop, select Properties>settings>advanced>troubleshoot.
Old 04-19-2010, 09:15 PM
Cool! That helped. Still a little glitchy, but at least I can get them to work now! I had to drop the accelerator down two notches from full right. Thanks!
Why does this happen though?
Pro Tools 2021.12
Old 04-19-2010, 10:53 PM
jeam25's Avatar
jeam25 jeam25 is offline
RAM model and brand.......
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 04-20-2010, 07:42 AM
So I should change the ram?
Pro Tools 2021.12
Old 04-20-2010, 07:47 AM
TOM@METRO's Avatar
What Ram are you running?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-20-2010, 08:49 AM
I have Dell 800mhz ddr2. What is the max I can install? I think 800mhz is the max. I have this mobo: http://cgi.ebay.com.sg/Dell-Inspiron...ht_2490wt_1165
Also, what would be my options at upgrading my mobo an still have my core 2 compatibility as well as compatibility with my current tower? PC specs in my sig.
Pro Tools 2021.12
Old 04-20-2010, 03:59 PM
Question Re: Plugin graphics (GUI) not loading/displaying properly???
Also, when buying 4GB of ram (for my 4 slot mobo), is it best to get "2 x 2GB" or "4 x 1GB"?
As for upgrading the mobo, would one of these along with some new DDR3 work with my Inspiron 530 case?: http://www.newegg.com/Product/Produc...13-128-418-Z01
Pro Tools 2021.12
Old 04-20-2010, 04:53 PM
TOM@METRO's Avatar
For your motherboard I think 4GB is the limit, but if you were to change motherboards you would be better off with 2X4 RAM as would allow for an upgrade. Also you can buy faster RAM and run it at reduced speed until you may decide to upgrade.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 04-20-2010, 05:06 PM
1. For your motherboard I think 4GB is the limit, but if you were to change motherboards you would be better off with 2X4 RAM as would allow for an upgrade.
2. Also you can buy faster RAM and run it at reduced speed until you may decide to upgrade.
1. Yeah, 4GB is the size limit, but I meant speed limit. Is 800Mhz the max speed I can use with my current mobo?
2. Is that referring to my current motherboard?
Now that I do some more research though, I don't think I can change motherboards with my computer. The I/O panel isn't removable!
Pro Tools 2021.12
PT LE 8.0.4 crash when loading up any VST plugin blast9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-30-2014 03:39 AM
Plug in graphics not fully loading johnnyo1124 VENUE Live Sound Systems 2 04-10-2012 05:25 AM
Anyone else getting graphics probs with melodyne plugin ? crizdee Pro Tools TDM Systems (Mac) 0 11-22-2007 11:23 AM
Plugin settings not loading Daire Winston Pro Tools TDM Systems (Mac) 2 02-28-2006 01:05 PM
PT7 plugin dsp loading and usage kchurko Pro Tools TDM Systems (Mac) 0 12-24-2005 02:04 PM
