Old 01-12-2011, 04:32 PM
jacub jacub is offline
Default How to get from PT7 to PT9 on windows7.
I just recently bought a new computer with windows 7 on it and wanted to crossgrade to PT9 from my PT7.1. I know it's possible but just not sure how to go about it. I know PT7 isn't compatible with windows7 but i would like to think that i don't have to upgrade to PT8 and then 9 right? I'm just not sure how it works. I've seen threads on going from 8 to 9 but not 7 to 9. Thanks in advance!
Old 01-12-2011, 07:48 PM
pianosound pianosound is offline
Default Re: How to get from PT7 to PT9 on windows7.
Jacub, PT's 9 is a full installer, and doesn't need any other PT's on the PC. Just purchase the 9 installer, and away you go!!
Good luck,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Old 01-12-2011, 07:58 PM
caruso7r caruso7r is offline
The things you will need are: 1. your qualifying hardware that needs to be registered. 2. your I-Lok ID as you will need to enter it for them and they will place the PT 9 license in your I-lok account. Depending on what kind of hardware you have, you may get PT9 for as low as $250.00... This info I gave to you is based on a online purchase of PT9. Obviously things will be different if you get it at a store.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 01-12-2011, 08:26 PM
Mike, you're talking about the crossgrade version?
Old 01-12-2011, 10:15 PM
sw rec sw rec is offline
Again, for all intents and purposes, it isn't a crossgrade. It's a full installer that will force you to remove previous versions anyway.
Old 01-14-2011, 04:42 PM
Thanks guys. I got it and everything works fine except for my external hard drive. I can't export audio to it from PT for some reason.
Old 01-14-2011, 11:47 PM
FWIW, with Windows 7, Avid now recommends USB2 drives and no longer recommends firewire drives(FW is still the choice for Macs). It seems Win7 has improved USB management that now is good for audio, but the new firewire drivers are still having some issues.
Old 01-15-2011, 11:46 AM
Thanks Albee. Tried the USB as well and it didn't work. I keep getting a message that says "you do not have permission to save in this location". Did i maybe read somewhere that PT doesn't work with Fat32?
Old 01-15-2011, 11:54 AM
Dism Dism is offline
Yes, FAT32 is not compatible for recording drives. Must be NTFS or HFS+.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-15-2011, 10:28 PM
Thanks Dism, so i guess that means i have to reformat my hard drive?
PT9, Windows7, PreSonus 16.4.2- need help wordmanjay Windows 19 02-29-2012 07:13 PM
PT9 on HP DV-6 windows7 64bit? Kissa3 Windows 12 02-25-2011 10:50 AM
Windows7 versions tmfergus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 11-28-2010 09:29 PM
Both hardrives get windows7? Jimibrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-05-2010 07:46 AM
windows7 64bit mediawest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 11-17-2009 11:05 AM
