drag file in, copies 2 iterations
Not a big deal but more curious than anything why this sometimes happens. Drag a file in to protools rather than using import, and it duplicates it. Sometimes it doesn't, sometimes it does, and ive even had a few cases where it make 2 copies. What's going on, what's the logic of the code behind this?
Re: drag file in, copies 2 iterations
Drag in what format and number of channel files? You mean it creates a copy in the audio folder within the session folder? That is a setting and pretty much best practice. Create additional copies maybe it is splitting R/L stereo files. You would need to give more precise description of what exactly you mean/are seeing.
no i mean it creates 2 tracks. "track name" "track name dup.1" They are the same. I just delete the duplicate no biggie but it's weird. Can't figure out why it does it when it does, and why it doesn't do it when it doesn't.
Done it with both mono and stereo files. Done it with both wav and mp3's.
Oh track duplicates... that one has been around a long time. e.g. http://duc.avid.com/showthread.php?t=404923 (and more)
Do you have a file you can share that does this? |
Yes that thread is exactly whats going on. Happened today but it was a mix for a client, don't feel comfortable sharing it publicly on here. Seems like that thread never touched on a why or a solution.
Yep. When it happens and you have a file you can share I will try to reproduce it and may want to look at the file/file header carefully. Other obvious things are to try trashing prefs and when you have a file that does this in a session then drag and drop that into to a new empty session (not from a template)... if that does not misbehave the same way then you may have corrupt session(s), or parent template....
... all just basic troubleshooting as I have no idea what is going on... I thought there were other old posts on this but after some googling it does not look like it. |
thanks Darryl
Consolidate from source media still copies the entire file | jab625 | Pro Tools 12 | 6 | 05-26-2016 01:43 PM |
UAD-2 Solo - How many iterations of the bundled plug-in can you run | FierceBrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-06-2010 04:27 PM |
Cannot Drag Mp3 File | stevviej20 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-18-2007 01:03 PM |
copies created on opening a PT file | Brian West | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-07-2006 09:08 AM |
Mystery File Copies | SiriusGibb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-05-2004 06:18 PM |
