#41
Re: Problems with PTLE? Post your configuration here..
Thanks for the response...just went into diagnostic mode and got a 9129 message after 2 minutes.........Please let me know what other info I can give you so I can be up & running. Thanks, John
#42
regards, Digidesign Technical Support |
#43
Hey there..yeah, I disabled all network adapters as well as Microsoft ACPI............willing to try something else
#44
Which model is this Toshiba? regards, Digidesign Technical Support |
#45
Yeah, I use pt soley for voice-over work. One mono track. I record, edit and send. It just cannot be using up my cpu. I have the Toshiba Satellite A70. John
#46
Problem
(Try to create a session or start up a saved session and then black screen and system reboot) I have been using digi 001 v6.1 for about the last year on this computer with (0) problems. Thought I would upgrade to digi 002. I can’t get it to work. First I tried installed the fire wire card hooked up the 002 and installed v6.1. Software installs fine. Reboot…. Open program and I get to main screen, Try to create a session or start up a saved session and then black screen and system reboots. I have tried to uninstall program and re install= same problem I have tried to uninstall program and install V 6.4 =same problem I have tried Dep fix= same problem I have tried to use a via chipset compatible fire wire card= same problem The control shows “open or create a new session" and seems to be communicating. Thanks for the HELP Processor Model : AMD Athlon(tm) XP 2200+ Speed : 1.80GHz Model Number : 2200 (estimated) Performance Rating : PR2607 (estimated) Type : Standard L2 On-board Cache : 256kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : 1 CPU(s) MP APIC : Yes System BIOS : Phoenix Technologies, LTD AM37308 System : Compaq Presario 06 DC477A-ABA S3100NX NA110 Mainboard : KM266-8235 Total Memory : 736MB DDR-SDRAM Chipset 1 Model : First International Computer Inc VT8375 ProSavageDDR PM266/KM266 CPU to PCI Bridge Front Side Bus Speed : 2x 133MHz (266MHz data rate) Total Memory : 768MB DDR-SDRAM Shared Memory : 32MB Memory Bus Speed : 2x 133MHz (266MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : S3 Graphics ProSavageDDR Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : MAXTOR 6L080L4 (75GB) Hard Disk : ST380022A (75GB) CD-ROM/DVD : PIONEER DVD-RW DVR-107D (CD 40X Rd, 24X Wr) (DVD 5X Rd, 3X Wr) CD-ROM/DVD : TOSHIBA DVD-ROM SD-R1312 (CD 40X Rd, 32X Wr) (DVD 5X Rd) Logical Storage Devices 1.44MB 3.5" (A:) : N/A Hard Disk (C:) : 71GB (2.7GB, 4% Free Space) (NTFS) Presario_rp (D:) : 3.6GB (749MB, 20% Free Space) (FAT32) CD-ROM/DVD (E:) : N/A Hard Disk (F:) : 20GB (5.2GB, 27% Free Space) (FAT32) New volume (G:) : 20GB (6GB, 31% Free Space) (NTFS) New volume (H:) : 35GB (13GB, 38% Free Space) (NTFS) Pro tools le (I:) : 366MB (CDFS) Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Printing Support FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Logitech-compatible Mouse PS/2 MultiMedia Device(s) Device : Realtek AC'97 Audio for VIA (R) Audio Controller Printers and Faxes Model : Symantec Fax Starter Edition Model : hp deskjet 3420 series Model : EPSON Stylus Photo R200 Series Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Adapter : Realtek RTL8139 Family PCI Fast Ethernet NIC Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
#47
I'm gonna get so drunk tonight!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!! That ACPI-Compliant Control Method Battery solved everything!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! MBox demo went through with no problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!! I could record 24+8 with 128 samples with DaveC-test plugins for 3:30 minutes, and I stopped the recording, not the system!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! HAHHAAA!!!!!!!!!! I'm prapably the happiest man in Finland!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Visit the lucky-mans band in web: www.rakkaudenammattilaiset.net And Ukko is my name!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HP Pavilion dv5-1035eo AMD Turion X2, 2,0ghz, 4gig ram 250gb LaCie MBox,PTLE7, REAPER, FW1814 |
#48
Re: BAD_POOL_CALLER
All drivers updated. BIOS updated. CS9 update verified.
Still no fix. While I appreciate your timely replies to my problem, I'm beginning to believe that I'm going to need some serious hands-on technical support. I need to do whatever it takes to get this $4,000 system up and running and I'm at the limits of my diagnostic abilities. How do I proceed from here? Can I send you the computer for diagnosis? Do you have authorized local diagnosticians? Can I trade this for something that works? Frustrated but hopeful, Scott |
#49
neeel
MBOX MINI PTLE 8.0.3 MAC OSX Snow Leopard Mac Mini 1.5Ghz Intel 2 Gig RAM ******************* |
#50
Digi,
Any suggestions for me? I posted back on page 2... Thanks, John |
Problems with PTLE? Post your configuration here...... | still_life_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2007 12:27 AM |
Problems with PTLE? Post your configuration here.. | DJ John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2007 10:06 AM |
Problems with PTLE? Post your configuration he | krsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-28-2007 09:59 AM |
Problems with PTLE? Post your configuration here.. | p3tch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-28-2007 09:46 AM |
Problems with PTLE? Post your configuration here.. | Gaba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2007 08:01 AM |
