Re: Please Help: New Avid PCIe Card added to old Core and Accell cards not working!
It actually occurred to me to do that too, so I did, and same thing. No worky! So that tells me that it is definitely the cards. The system profiler on the Mac says that all the slots are working when all the cards are in, and of course the older Accell card slot works just fine with the older card in it. Still at a loss. Not sure what to do but I just thought you would want to know that I tried what you suggested... Thanks.
Sterling Winfield Producer/Engineer |
I have also just switched out the new flex-cable for the older one that I know works. Still no dice! WHAT IN THE WORLD IS GOING ON HERE???!!! I KNOW I AM NOT THE ONLY PERSON THAT HAS EXPERIENCED THIS. Any more suggestions???
Check for R35 missing on that card
Along with others in the proximity
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
R35... Is that a component on the card itself?
Yes, the newer card is missing component R35... Now what?
#16
It's not covered under warrenty because it can only fall off when the card was installed and was likely applied with a little force?
I can repair it for $75 (next day turnaround) (( labor only )) I believe avid charges $100 plus shipping and more for express Advance replacement is around $200+ I knew it was the problem because I've fixed it to many times already If you choose you can reach me via the link below
#17
I will keep that in mind if I run into any more trouble. Thanks for the quote...
#18
Cool
Be carfull if attempting this repair yourself There circuit traces surrounding this part if a micron of extra solder slips off the pad or component it will short and man you'll be hating life It takes SMD tools to rework it correctly, a soldering iron will work but will also over flow this small area with solder to adjacent pads Good luck and reach out if you need it repaired
#19
Lynx Hilo Thunderbolt 2013 Retina Macbook Pro 2.7 16 GB of RAM PTHD 11.3.1 OSX 10.10.1 |
#20
Well, I'm glad that the folks I bought it from will stand behind me. I am in good hands. Thanks all for helping me find the issue.
AVID HD NATIVE PCIe CORE CARD CHEAP!!! | Killbert | Buy & Sell | 0 | 01-09-2014 06:44 AM |
PCI-X CORE Card and 2 Accell Pci-X Cards | Zeljko2 | Buy & Sell | 3 | 10-24-2013 12:29 AM |
Digitest - Slot #0 Core Card PCIE - Failed but Pro Toools is working fine. | DrFord | Pro Tools TDM Systems (Mac) | 3 | 06-19-2011 11:20 PM |
Mac Pro Dual Quad core compatable with HD pci core & accell cards? | PT8716 | Pro Tools TDM Systems (Mac) | 3 | 06-28-2010 07:35 AM |
Chips on the Accell PCIe cards | bad jitter | Pro Tools TDM Systems (Mac) | 3 | 01-14-2006 10:59 PM |
