Old 03-31-2021, 05:48 PM
kavode kavode is offline
Default Maxim presets won't load
I'm trying to use Maxim's "Radio Limiter" preset, but it is not showing up in Pro Tools 11 on Windows 10.
I can see the Radio Limiter preset in the User Library c:\Users\MyUserName\Documents\Pro Tools\ but all that opens in Maxim is factory default.
When I go to import Radio Limiter.tfx, I get this error message:
"These files could not be imported because there are already settings files with that names in the plug-in's settings folder: Radio Limiter.tfx"
Please help!
Old 04-01-2021, 07:39 AM
Default Re: Maxim presets won't load
Your description is a bit confusing as to how you are trying to load a preset. If you look at the plugin(any Avid plugin), across the top you will see Preset. Directly below that is a button that says . Clicking on that SHOULD open a list of presets.
Having said that, Maxim is a rather simple plugin with only a few parameters, so I suggest tweaking until it sounds the way you want(and be aware that it is NOT a highly-regarded plugin for mastering). Here's a youtube tutorial on using it:
https://www.youtube.com/watch?v=UI1X7nymUVs
I suggest trying the lowest version of iZotope Ozone for simple mastering(assuming you are NOT using Pro Tools First)
Old 04-01-2021, 11:23 AM
Thanks, Albee. I ended up manually loading the presets into the Maxim Plugin Settings folder (even though they were already there), rebooted, and the presets are there now.
Not sure why PT didn't see them, but I'm good now.
Old 04-01-2021, 11:25 AM
I was using Maxim for this project as it's a radio broadcast client, and they use this exact preset in Maxim for their commercial spots. So I wanted to make sure I matched their specs.
Old 04-01-2021, 12:24 PM
Glad you got it sorted
HTML code is On
Cannot load presets. fustrun Eleven Rack 8 04-27-2016 05:56 AM
Cant load presets pissed_off Eleven Rack 21 07-09-2013 10:23 PM
Avid Maxim Presets Tha_Clinic Pro Tools M-Powered (Win) 3 07-18-2011 03:46 PM
MAXIM won't load into Pro Tools LE v8 nalon saul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2009 09:54 AM
help! dfx still won't load presets in 5.0le! coaster Pro Tools TDM Systems (Mac) 1 01-11-2000 07:53 PM
